The Pioneering Performance GTB2260 Emporium
Vendor , w/Business number
Bournemouth UK
Bora ARL
The webshop is now live at last!
https://pioneering-performance.com/
Please take a look and feel free to message us with your thoughts and comments / questions.
Hi guys – I’d like to take a moment to introduce me and my company – Pioneering Performance Ltd in the UK. My name is Adam and I have been working in the turbocharger industry for over 15 years now, and have quietly built several turbos to grace these pages in the past. My current project is the result of a few years work, and can be found on my webshop www.pioneering-performance.com (oops its not live for a couple more days...) We can be contacted at pioneeringperformance@gmail.com or on https://www.facebook.com/pioneeringperformanceltd/
We have designed, and cast / finish machined all proudly in the UK, an OEM looking manifold / turbine housing to bolt onto the 1.9 8v TDi heads, which will accept the GTB20-22 etc range of turbocharger CHRA.
This manifold (or turbocharger built into it) will bolt straight onto the cylinder head without fouling on any of the inlet manifolds tested to date, and will integrate perfectly with most of the OEM functionality. The OEM lower support bracket (the GT1749VB style one for the hole pointing at the block not the earlier VNT15 style for the hole parallel to the block) will rotate and bolt on providing superior support and fantastic longevity. The OEM 3 bolt downpipe mounts straight up. The OEM oil drain bolts straight up (when using an Audi origin 2260 turbo). Your original actuator and bracket can be used. The metal GT1749VB (721021) turbo inlet pipe will mount straight up with a silicone reducer. The EGR system will bolt up to the blanked off flange, which makes for an almost OEM looking install. The EGR port is not functional, but we have a pilot plotted for if you want to drill and tap for an EMP or EGT gauge. We have tried to make this as practical and as universal as possible, but still with quality and performance as the top design factors.
The castings are cast in the UK by a specialised foundry, with around 80% of their business made up by small runs of pre-production turbine housings for the likes of Garrett and Borg Warner. We chose the most temperature resistant material to ensure the life of these items, and they are finish machined here in the UK using various CNC processes.
We have a comprehensive webshop which is nearly up and running (still a bit of a work in progress in places so please bear with us), and offer for sale anything turbo related, especially performance orientated.
Bournemouth UK
Bora ARL
What we stock in the GTB Emporium
We can source pretty much every part you need to rebuild or upgrade your GTB turbo. (Actually pretty much any turbo you care to play with!) Covering the “smaller” GTB frame sizes – GTB14-17 and the “larger” frame sizes GTB20-22; and ranging from the smallest nut, washer or O-ring up to major components like turbine wheels, compressor wheels and CHRA. We manufacture our own high performance bespoke parts, and stock many of the popular MFS / billet compressor wheels. If you can’t see what you are looking for simply drop us an email and we’ll do our best to sort you out.
A small example of some of the parts we have in stock at the moment, everything is listed on the shop.
Compressor wheels cast and billet
Sizes for GT/GTB from 49mm up to 71mm and all things weird and wonderful inbetween!
Turbine wheels standard and our own custom lightweight
We carry standard turbine wheels for pretty much anything, and manufacture the lightweight Audi and BMW sized GTB2260, and also the AMG GT23 ones to fit into the GTB units.
VNT Cage and Nozzle rings,
Compressor housings and CHRA - billet, cast, lightweight turbine, Vacuum converted..........
3L3M3NT
Sturgeon Bay, WI
04 Jetta GLS TDI, 04 RTDI
Talk about making it easy to upgrade to a GTB2056VK or a GTB2260VK :eek:
I'll keep on checking back for when the website is up and running. This way I'll see if I can afford to replace my VNT-17/22 with one of your PnP turbo setups. :D
3L3M3NT
Sturgeon Bay, WI
Wow! That's a nice improvement over the factory turbo. :eek:
For the VKLR turbos, do you utilize the liquid cooling part of the turbo or can you run them with just oil?
Bournemouth UK
Bora ARL
It is highly recommended to run them with the water cooling. The ceramic bearings we use are found in the oil only cooled 1752VRK, however that bearing housing is somewhat different inside with an air cavity there to isolate the oil from the heat. The VKLRs don't have the air cavity and so would benefit from having the water circuit enabled. Better safe than sorry...
MAXRPM
US
00 Jetta and 99.5 Golf, 2015 Passat TDI,BMW 2
nice work on these turbos,
3L3M3NT
Sturgeon Bay, WI
Could one buy just the casting if they already have a CHRA and everything else needed to get the turbo working?
Bournemouth UK
Bora ARL
Absolutely - that’s the whole idea of this product. If you have a functioning GTB2260 you can unbolt the 6 M6 bolts and washers that hold the CHRA into the turbine housing, and swap the entire assembly into our manifold and create a largely plug and play solution. (Excluding the work needed in completing the vacuum conversion).
We have plenty of stock available for £525 plus VAT and shipping.
shanky887614
uk
vw caddy arl
these manifolds work great, im running one with a gtb2265vk from skilla turbo
should see over 300bhp with it, got a highlift cam and firad+80 injectors (will be fitting a ported head which might have oversized valves...)
3L3M3NT
Sturgeon Bay, WI
That's great to hear! This sounds like a great solution for me when I upgrade from my VNT-17/22, since the exhaust will bolt right up. :D
That's my plan down the line with the port and polished head with larger valves and an upgraded cam. I was planning on going with R783 nozzles, since that should allow me to hit my goal of 230whp and still be responsive enough to feel like the VNT-17/22, but have a heck of a lot more on the top end. :D
3L3M3NT
Sturgeon Bay, WI
It's great to see your website is up and running! Now I just need to come up with the money to purchase one of your turbos, after I figure out what turbo to go with. :D
Keep up the great work!:)
Castlegar BC
2003 Jetta TDI
First off i want to thank Pioneering Performance for offering such a great turbo I have ran a ton of turbo's in the past and nothing comes close to what they offer I have a 2260 with 11+0 wheel my EGT's never get over 1350F with my 12mm pump and .300s nozzles.
Here is a dyno i did please note only the 1st pull is 1:1 pull 2 and 3 are 1-5th gears
racerxtdi
Outside of Philly
2003 Jetta 5spd GLS
How in 1 run your outputting 445 lb-ft then the next 602 lb-ft? And what boost are you using for those # 50PSI?
Please us about your engine work to handle all that torque
Bournemouth UK
Bora ARL
3L3M3NT
Sturgeon Bay, WI
It's great to see this kit released Adam. I really wish this would have been available last year when I made the switch from a VK style turbo to a VKLR style turbo. I bought a kit online, but had to modify it to work for my application, which cost me more than double than what I originally paid for the kit itself.
Keep up the great work and I can't wait to see what you come out with next. :)
3L3M3NT
Sturgeon Bay, WI
Well Adam, it's time to pull the trigger on one of your turbos. I'll email you to confirm everything we've been discussing.
-Eric
3L3M3NT
Sturgeon Bay, WI
Nice looking work! Is there a reason you don't offer anything for the 3.0 TDI?
My suggestion would be to email him and see what he can get for you. You'd be surprised what he can get his hands on. He works with other models and different brands when I was chatting with him via email after I had ordered my turbo.
Wow, how did I miss this! 🔥
They make some pretty sweet turbos for the 1.9/2.0 TDI. I'll be getting mine at some point and time and can have pictures taken when it gets installed either this summer or this fall.
Andyinchville1
Virginia
2003 Jetta TDI wagon, 5 sp, 226K miles
HI,
I have the stock turbo on my car (VNT 15) and I was thinking of upgrading it since it has about 400K Miles on it now (still no issues and intercooler only has about 3 tablespoons of oil in if after about 28K miles on the oil change).
My goal for the turbo upgrade (over the stock VNT 15) is LESS exhaust restriction (for fewer pumping losses and greater efficiency cruise ) i.e. better MPGs AND ideally about the same response (i.e. no lag ) along with hopefully better top end (although if you can't ALSO have top end I would sacrifice on the high end for better response AND LESS restriction on the lower end ... I read on the Kerma site that a larger turbo can get better MPGs at cruise due to less restriction at cruise ... seems to make sense since I got better MPGs after I installed my 3" cat back exhaust .... less restriction is better).
FWIW I tend to operate on the lower end of the RPM (very seldom going above 2500 RPM unless doing an Italian Tuneup to keep the vanes free) and boost range.
I would like to be able to use my standard 3 bolt hole downpipe ( I have a Kerma 3" turbo back system) and I would ideally like to use non custom piping for ease of use (I was looking getting the Kerma 2" intake piping that they still have available for the VNT 17 set up BUT Im guessing if you recommend bigger than the 17 series maybe a coupler could have to be used ? (I think they go up to 2" pipes).
Anyways ,
I'm not sure if I want to get as fancy as liquid cooler (unless there is a kit available to get it to work easily) .
I would not mind BB since I hear they spool faster / earlier ? BUT only if they are as reliable as the standard "oil" system (how reliable are BB turbos?.... I need longevity since I drive for work and alot of miles to boot .... plus due to the expense I would like it to hand around for awhile .... at least as long as stock ?).
I don't mind hybrids BUT I have read that many people don't like them since the bearings are not necessarily OEM quality ??
Given the above what do you recommend ? I am not adverse to buying a better exhaust manifold of that flows better and makes the install more "turn key" bolt on.
Thanks in advance for any and all help.
Andrew
3L3M3NT
Sturgeon Bay, WI
I got my Pioneering Performance turbo a few weeks ago and finally have some time to post some pictures.
After talking with Adam about what the goals are for my 2004 Jetta that currently has a VNT-17/22, PD150 injectors, PD150 head bolts, 4 BAR MAP, PD150 MAF in a R32 MAF housing, FMIC, and 2.5" downpipe to 3" exhaust with Aeroturbine muffler. He recommended I go with one of his GTB2260VKLR turbos.
I'll hopefully get around to installing it in the next month or so and can report back how amazing the turbo is.
Anyway, on with the pictures. :)
So, if you're considering getting a bigger turbo, talk with Adam about which turbo is the right one for you. (y)
ChippyTDI
Midlands, UK
Golf MK4 GTTDI 1.9
Any updates?
Very interested in Pioneering Performance's GTB2260VKLR for my rebuild but awaiting your review of the performance haha!
