invader
I know 01m's are crap.
My daughter got this 96 Jetta that was intermittently having a minor shift flare problem so I did a fluid change.
Also changed out the gauge cluster since the old one was only working about 5 % of the time.
Put in a used cluster I bought and all was well for about 4 days.
Then she told me the speedometer stopped working again and there was a CEL. Had not seen any CEL's before this.
So I got out the vag-com and checked the codes.
Didn't note the actual code #'s but there were two of them.
One for warning lamp intermittent ground open, or something like that and one for vehicle speed sensor implausible signal intermittent.
So I cleared the DTC's and they stayed off.
Then I did a transmission reset using the key on, accelerator to the floor for 10 seconds then let off and turn off key.
I did this because I had changed the trans. fluid a week ago and read somewhere that this should be done after the refill and I hadn't done it.
So I start up the car, put it in reverse and the thing is chugging like a steam locomotive.
Today I went back in with the vag-com to try to look at the trans. The vag com can not communicate with the TCM. Says could not open controller.
Did I somehow fry the TCM? Is there a fuse or something that went bad that powers the TCM?
I am pretty sure the chugging symptoms is due to no control from the TCM.
Any help would be great.
Thanks,
Invader
Thanks,
Invader
