Old March 13th, 2019, 01:12   #256
jason_
That can be from a start up and some idling and easy driving.
If. New catch can the ash should be nearly nothing.
Sent from my 2PS64 using Tapatalk
jason_ is offline   Reply With Quote
Old March 13th, 2019, 07:46   #257
Smashed Ixnay
OK so I just talk to the service rep and they are going to change a few things with the biggest being a high-pressure fuel pump. He said Volkswagen does not think it went all the way into the system, thus it not being the $8k bill it could be. I’m glad it’s covered under warranty, but this sucks at the same time. They said it’ll be ready tomorrow with me owing $0 for the repairs
Smashed Ixnay is offline   Reply With Quote
Old March 13th, 2019, 12:39   #258
bizzle
bizzle's Avatar
Sorry, I'm not clear on your second sentence.
The DPF was replaced about 5 months ago during phase 2 fix, I believe. So the calculated soot should not be over 600g? Or you're saying it's normal from idling and easy driving?
bizzle is offline   Reply With Quote
Old March 15th, 2019, 06:42   #259
jason_
Soot and ash are two different materials to measure and for the vehicle to work with.
After X grams of soot or X miles of driving the car regens to turn all caught (calculated or measured) soot into ash.
Dpf replacement is phase 2B, not phase 2A. Check your invoice.
24g is normal trigger load, 26 or 28? you get a light telling you to get stay on the road for a 20min drive.
Ash level seems I think has been I think 1 gram for every 10k. If you're not using low ash oil it'll climb faster.
I'm at about 40k, my ash load is 16g. I adda touch of 2stroke oil to every tank fill.
, and at 75000 miles I'm stopping at a dealer to get phase 2B for new Dpf. It's in the paperwork explaining the procedure.
Old March 15th, 2019, 09:21   #260
Smashed Ixnay
Looks like my car is fixed, but my wife’s 2015 Q7 TDI we bought a few weeks is now not wanting to turn on. Audi came to pick it up, so we’ll see what the issue is.
Old March 15th, 2019, 12:19   #261
bizzle
bizzle's Avatar
The oil ash volume is .07l and oil ash mass is 30.8g
I'm at 76K miles, but my phase 2 was done around 70K and phase 1 was at 65K. My understanding is that my mileage wasn't low enough to warrant a phase 2a and 2b, it was simply phase 2 for higher mileage vehicles.
Old March 15th, 2019, 13:55   #262
Smashed Ixnay
Got my car and everything seemed great. Drove off about 2 miles later my check engine light came on. Code is for some sensor near the windshield wipers. They said they don't know what VW wants them to do, but the car is perfectly safe to drive. He said it's part of the emission stuff, so once they get told what to do they'll go from there.
Old March 18th, 2019, 16:36   #263
Smashed Ixnay
Driving home today going about 70mph I felt my car lose power. I’m back to square one. Once the car gets speed it’s not bad, but from a dead stop it’s a dog. off the line. I wonder if VW would give me a loaner if it’s going to take another week to “fix” it this time.
I recorded a video (sorry pops started to talk some).
https://youtu.be/GAaySoQuxa8
I’m going to drop the car off tomorrow morning. I am able to shut the car off and the issue goes away (unsure for how long). I’ll take it as my high pressure fuel pump was never the issue to begin with since it’s still doing it. I guess that’s a good thing and bad thing as it did not fix this my issue, but I got a new HPFP out of this.
This sucks.
Old March 20th, 2019, 08:15   #264
Smashed Ixnay
Not sure what these are, But these are what made my check engine light come on Friday after they fixed my car. I took the car immediately back after leaving when my check engine light came on and they checked them. . Nothing was wrong with them and they were completely fine, so they told me to just drive the car because it is just something to do with the emissions and it’s not a safety issue. Apparently it was a safety issue.
Old March 21st, 2019, 09:53   #265
yurkin89
Originally Posted by Smashed Ixnay View Post
Not sure what these are, But these are what made my check engine light come on Friday after they fixed my car. I took the car immediately back after leaving when my check engine light came on and they checked them. . Nothing was wrong with them and they were completely fine, so they told me to just drive the car because it is just something to do with the emissions and itís not a safety issue. Apparently it was a safety issue.
DPF sensors 04L-131-552-DL
Happened to me as well, if you would have kept on driving it would of caught on fire.
yurkin89 is offline   Reply With Quote
Old March 21st, 2019, 10:30   #266
93celicaconv
I opened the hood of my 2015 Passat TDI SEL Premium last evening, after seeing this picture. I have the insulation wrapped item too, but it wasn't clear then to me what it was. Thanks for stating what that is. Obviously that insulation wrap is there for a purpose. I suspect the item gets quite hot, so the insulation wrap protects what is outside of the wrap? If so, this part must have gotten hotter than it should have for some reason. Any idea why it might have gotten so hot as to burn the sensor up?
93celicaconv is offline   Reply With Quote
Old Yesterday, 02:22   #267
jason_
Yah, if you had some higher miles on it prior to phase 2, then they would of just done everything.
So your good. Seems the ecm is keeping up on things with the new hardware.
Now delete and tune, , and resell it to someone who has surpassed their Dpf...
2.0 Gen 1 post fix impressions, issues, etc. Snowyroad Dieselgate - VW Group Emission Scandal 334 February 6th, 2019 21:08
2015 Gen 3 Fix Phase 2 ddorrer Dieselgate - VW Group Emission Scandal 434 January 6th, 2019 15:23
Gen 3, Phase 2 Fix Zoso VW Passat Family (NMS and B7) TDIs (2012+) 7 May 11th, 2018 15:05
2015 Gen 3 Phase 2 Status? ddorrer Dieselgate - VW Group Emission Scandal 4 March 19th, 2018 09:35
Gen 3 Phase 1 fix, Test drive impressions bevo_7 Dieselgate - VW Group Emission Scandal 22 June 5th, 2017 21:09
Page generated in 0.13465 seconds with 12 queries
[Output: 111.52 Kb. compressed to 94.88 Kb. by saving 16.64 Kb. (14.92%)]
