Old March 9th, 2019, 20:06   #31
ToddA1
Fuel Economy: Dismal
Camshaft has play...? Is this a new cam? Do you have the original cam?
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old March 10th, 2019, 01:25   #32
lisab4
lisab4's Avatar
It's a newly rebuild head I installed
1996 Passat B4 1.9TDI 1Z
lisab4 is offline   Reply With Quote
Old March 15th, 2019, 08:43   #33
lisab4
lisab4's Avatar
Anyone?
Old March 16th, 2019, 05:48   #34
ToddA1
Never answered this.
-Todd
'97 B4: Stock
Rabbit build
Old March 16th, 2019, 10:27   #35
lisab4
lisab4's Avatar
Original one as for as I know. Had the whole head rebuilt. Don't know what he did, but don't think he replaced the head.
Old March 17th, 2019, 05:40   #36
ToddA1
Curious if the cam bearings were aline bored... this may be your issue. There shouldn’t be noticeable play. Not sure if any type of repair sleeve bearings are available for this.
-Todd
'97 B4: Stock
Rabbit build
Old March 19th, 2019, 05:12   #37
iluvmydiesels
TDI(s): AHU
Fuel Economy: mk3 ~43mpg
Originally Posted by lisab4 View Post
I've also seen that the camshaft has play in it. I see the bolt from the camshaft gear move when the engine is running. it is noticeably going up and down.(
so you havent really given too much other info on this. is the camshaft gear also 'moving' like the cam bolt?? if the cam has play the gear would also 'move' id think. is it the stock bolt? did you happen to put a different bolt and washer in?
for one id turn the crank to TDC and check out if its still in time. then check that the bolt is tight!!. make sure its @ about 45ftlbs.
small fleet of mk3 tdi
have exp on mk1&2, idi
other vw interests
iluvmydiesels is offline   Reply With Quote
Old March 20th, 2019, 23:20   #38
Digital Corpus
Digital Corpus's Avatar
-Todd
None are around that I'm aware of, but come could be made to fit if the right dimensions and machining is done.
Turbo Upgrade | Engine Rebuild | Photos | Lighting Mods
Dyno Graphs | 4-Bar sensor | GTB1756VK | Hot-swappable 2.5" down pipe | R520's | PD130 intake manifold
Digital Corpus is offline   Reply With Quote
Old Yesterday, 01:22   #39
lisab4
lisab4's Avatar
I'm putting her back together as we speak and will send her off to a shop afterwords. I know too little myself to keep trying. I do not want to cause further damage. I'll keep you informed regarding the diagnosis.
DrVolks.com installs a Bilstein Sport and H&R Spring combo step by step video CNGVW Upgrades (non TDI Engine related) 0 May 12th, 2016 04:22
Video: Polar FIS Step-by-step Install - 2014 JSW TDI aCab VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 19 January 20th, 2016 09:21
How to Do A Compression Test - Step by Step for beginners A4 TDI y2kbird TDI 101 32 August 20th, 2006 17:55
anyone interested in posting a step by step for intake manifold removal/cleanign? gboss VW MKIV-A4 TDIs (VE and PD) 2 March 7th, 2002 06:02
Fuel Filter Change - 101: Step By Step Guide Turbo Steve VW MKIV-A4 TDIs (VE and PD) 19 January 31st, 2002 08:28
Page generated in 0.11875 seconds with 12 queries
[Output: 93.52 Kb. compressed to 79.89 Kb. by saving 13.63 Kb. (14.57%)]
