Go Back   TDIClub Forums > VW TDI Discussion Areas > OBD Scanners
OBD Scanners Discussions on using On Board Diagnostic (OBD) scanners/ Diagnostic Equipment related to TDIs
Old March 10th, 2019, 13:00   #1
bizzle
bizzle's Avatar
Default HOWTO: VAGCOM Live Gauges
I have read a few threads about setting up hex net live gauges but haven't seen a step by step.
Could someone who has a nice setup of gauges post a step by step from everything, including the gauge sizes, how to save the template, and then the most important gauges to monitor while driving?
The ones I'm most curious about are boost and EGT (and region if EGT won't cover it) but am I missing anything that I should be watching?
I saw like a hundred sensors, some of them unlabeled, but nothing simply "EGT" and anything I did would create a graph instead of a nice looking gauge.
Also, is there any way to set up any of this while the car is off and can we trade templates after they're all setup?
bizzle is offline   Reply With Quote
Old March 11th, 2019, 08:57   #2
bizzle
bizzle's Avatar
I figured some of it out...I should be able to make a howto once I've got it all done.
Right now I'm trying to figure out the ID'S of the EGT. Am I supposed to be logging exhaust temperature banks 1 and 2?
Old Yesterday, 00:16   #3
Chasen90
Chasen90's Avatar
TDI(s): golf
i also have the same question as the poster,anyone can put a guide on it?
Chasen90 is offline   Reply With Quote
vagcom boost live reading TurboBugger TDI 101 8 January 27th, 2010 07:23
Vag com howto? Nico3d3 TDI 101 15 June 7th, 2009 05:47
howto use etka unixb0y VW MKIV-A4 TDIs (VE and PD) 1 November 29th, 2003 13:10
CCV Howto? arootbeer VW MKIV-A4 TDIs (VE and PD) 3 March 13th, 2003 15:32
if you were going to install gauges whats your top three most important gauges? Y2K BORA TDI Power Enhancements 39 December 13th, 2001 00:49
Page generated in 0.06367 seconds with 12 queries
[Output: 57.56 Kb. compressed to 52.26 Kb. by saving 5.30 Kb. (9.21%)]
