Old September 13th, 2018, 15:49   #1
WildChild80
WildChild80's Avatar
Default 3 point socket
If I had a junky 6 point 24mm socket and ground every other flat spot all the way to round, would that work to get that plug out? Maybe I'm a cheap'o but 20 bux is expensive to rent a tool...I understand some of that is shipping but if I can make one for almost free I'm all about that and I'm out in the boonies so no help from bigger shops that might actually have one
WildChild80 is offline   Reply With Quote
Old September 13th, 2018, 18:07   #2
AndyBees
AndyBees's Avatar
What plug are you trying to get out?
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
AndyBees is online now   Reply With Quote
Old September 13th, 2018, 18:26   #3
WildChild80
That big plug in the middle of the injection lines
I've got a leak on the IP and I think it's that plug or whatever it is
Already changed the pump head seal twice and the QA is sealed now...replaced the crush seals under the nipples in the pump head, still a fast drip
Old September 13th, 2018, 18:52   #4
AndyBees
AndyBees's Avatar
You need to leave that plug alone.
If you have a leak it is the O-ring on the pump head ... the cast iron thingy with the four injector line fittings!
To my knowledge, there is zero Threads here that guide you through removing that big nut or what ever it is called.
The re-seal kit, which has more than you'll ever need, costs less than $20.00 shipped. Also, Runobeer has a very good video and write-up how to change the pump head O-ring.
Lastly, the rubber gasket for the top piece (forgot the name) and the next one down also comes in the kit. The top one is known to leak.
Old September 13th, 2018, 18:56   #5
AndyBees
AndyBees's Avatar
Scroll down the page in this link for pics and narratives of when I changed the big O-ring on the pump head. It is fairly easy but can become a catastrophic goof if you mess up (pull the head out too far).
http://forums.tdiclub.com/showthread...276798&page=52
Old September 13th, 2018, 19:12   #6
WildChild80
I've already changed that seal
Old September 13th, 2018, 19:12   #7
WildChild80
Twice, I thought I messed the new seal up
Old September 13th, 2018, 19:16   #8
WildChild80
There is a wet spot coming from that plug down to the bracket and that's where it drips, I took the bracket off to confirm it's not coming from the pump head seal
Old September 13th, 2018, 19:25   #9
AndyBees
AndyBees's Avatar
Hmm.
Well, I'm at a loss as I've never seen anything about removing that plug for a re-seal.
Maybe an experienced guru will chime in here.
BTW, I'll send out those notes, etc., on the schematics in the morning.
Old September 13th, 2018, 19:53   #10
WildChild80
Thanks Andy
Old September 13th, 2018, 22:08   #11
KrashDH
TDI(s): 2002 Golf
It can leak from there (3 sided)
http://forums.tdiclub.com/showthread.php?t=346928
Check out the other link in there too (post 3)
KrashDH is offline   Reply With Quote
Old September 14th, 2018, 00:14   #12
KLXD
It's just a plug, nothing will fall out when it's removed. Has an o-ring that sees case pressure and a knife edge seal that sees injection pressure. I've read it's a one time use part but I've reused it.
Grinding a socket will work but I don't know what size.
You sure it's not the leeetle center plug?
Saying no to gas for 25 years:
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
KLXD is offline   Reply With Quote
Old September 14th, 2018, 07:35   #13
burn_your_money
While it's not as common of a seal to leak, they do fail. As mentioned, that plug is technically a 1 time use. When I worked at a fuel shop, we would inspect it and most often it was safe to reuse again. The knife edge gets crushed so depending on how crushed it was determined whether or not it would be reused. Odds are you'll be fine.
I think that plug gets torqued to 100 ft-lbs.
If you search on VWdiesel.net you'll find the proper sized socket to cut down. It's the same plug on the older IDI engines. It might be in the FAQ over there.
Or spend $33 and have all the tools you need
Amazon link
burn_your_money is offline   Reply With Quote
Old September 14th, 2018, 16:25   #14
WildChild80
I looked and I couldn't find anything using Tapatalk anyway...I found some chrome vanadium sockets in my toolbox, 15/16 and 1 inch and I'm sure I can make one of those work...and I had 20 bux store credit on my AutoZone card and their Dremel was on sale, didn't want the Dremel just the tools inside but it didn't cost me anything...
Old September 20th, 2018, 11:56   #15
WildChild80
Well I made a 3 point 15/16 socket and it worked like a charm, cut every other flat spot off.
The seal looked ok but replaced it anyway and it's good now...
LF: 30 mm 12 point axle socket daniel_mad Ontario 7 November 27th, 2017 10:38
FS: 30mm 12 Point Impact Socket 1/2-Inch Drive. Sunex 230zm For Wheel Bearing Nut. TdiTaff Private TDI Items for Sale/Wanted 0 August 15th, 2016 21:24
12 point socket GuyGuy TDI 101 11 June 29th, 2006 07:37
Looking for a 1/2" Six Point Metric Socket Set VelvetFoot TDI 101 12 April 11th, 2004 21:14
Multi point socket - Steering wheel removal djdluck TDI 101 7 February 26th, 2004 20:22
Page generated in 0.18377 seconds with 13 queries
[Output: 126.22 Kb. compressed to 104.91 Kb. by saving 21.32 Kb. (16.89%)]
