Old February 10th, 2018, 11:28   #1
bigkahuna360
Fuel Economy: ~55MPG, 43MPG
Default '06 TDI Aux Heater Removal?
Trying to take out the auxillary heater in my '06 to see if I can fix it myself or if I have to buy a new one. I was able to locate where it lives, but I can't seem to remove the drivers side panel covering the whole thing. Is there a guide to removing it?
2002 Jetta GLS TDI 333k Miles and counting!: DLC 1019's, Malone Stage 3, VR6 clutch, 11mm fuel pump, mufflerectomy
bigkahuna360 is offline   Reply With Quote
Old February 11th, 2018, 20:47   #2
narongc73
been a while since I took mine out but I didn't remember it being that hard. Panel pulls out easily enough.
narongc73 is offline   Reply With Quote
Old February 11th, 2018, 21:49   #3
bigkahuna360
Took out the panel underneath the steering wheel and took out the screw next to the pedal, but there seems to be something holding it tightly right below there. Is there some sort of clip or something else I'm missing?
Old February 13th, 2018, 09:12   #4
kfcoltn
Fuel Economy: 43-45 MPG
I just accessed mine a couple weeks ago. I had to slide the panel back and flex it out in the middle. There are plastic interlocks on the backside that hold it in place. If you break one, like I did, its not a big deal the screw still holds it in place.
06 Jetta BRM - Colt Stage 1 Cam, Malone Stage 1.5 Tune.
2-13-18 - 375,000 miles
kfcoltn is offline   Reply With Quote
Old February 13th, 2018, 12:26   #5
bigkahuna360
Thanks, I'll give it a shot today and see if it's just being 12 year old car tough.
Old February 14th, 2018, 15:16   #6
bigkahuna360
Holy crap, never again. This is such a PITA that I'm actually willing to pay my mechanic to do this for me. Got the panel off, had to pull back towards the seat after yanking hard on the upper piece. (Don't worry about pulling too hard) Getting these the screws and nuts off after that was the worst part just due to the angle. Almost got it out but I ran out of time.
EDIT: So others have it available, I found a couple pictures that helped me see how the panels went together.
https://www.pelicanparts.com/techart...er_Console.htm
Mythical Aux. Heater in TDI's Farrsolo TDI 101 25 May 3rd, 2015 18:26
MK5 Jetta TDI Parts - GTI Steering Wheel/Aux Heater/Springs piran21 Private TDI Items for Sale/Wanted 1 November 14th, 2014 09:54
2006 Jetta TDI cooling fans turning on when Aux heater turned on Diesel_Powher VW MKV-A5 Golf/Jettas 11 November 29th, 2013 16:02
Aux Heater on Passat TDI? MyAvocation VW Passat Family (NMS and B7) TDIs (2012+) 32 October 31st, 2013 11:47
2010 Jetta/Golf TDI Aux Heater Highline VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 0 April 8th, 2010 22:45
Page generated in 0.15508 seconds with 13 queries
[Output: 73.32 Kb. compressed to 64.15 Kb. by saving 9.17 Kb. (12.51%)]
