Caddyrage
Hi everyone. I hope you can help
My mk3 caddy 1.9tdi, BLS engine code is very gutless.
I got the van with 82k on the clock and with a new turbo fitted.
It struggles to even get to normal traffic speed.
You can hear the turbo spinning up.
I've had it on vcds and after deleted old messages, nothing new came back up other than it missing the outside air temp sensor.
I've cleaned the egr which looked ok to start with
I've tried another maf, n75 and boost pressure sensor off my mates caddy.
I did get mad on the last test and booted it, lots of black smoke but had poke. It then dropped and eventually died on me.
Just incase I needed to tow home, I removed my mates maf sensor to find the intake filled with diesel fumes.
The caddy still doesn't start, just turns over.
There's also a little play with the turbo impeller even though it looks brand new.
Any help would be greatly appreciated as this is supposed to be my new daily to go work in.
Cheers, lee
Cheers, lee
