Ecu came back from Malone yesterday after Immo defeat.
Installed, cleared all codes. Drove this morning to do a full cycle test and I am still in limp mode. If anyone sees anything in these codes that looks like my culprit, please let me know.
Code output:
Report by CARMAN for VAG
Module: Main gateaway
Part #: 7N0907530C
Component: J533 G
Coding:
Fault codes: OK, no faults detected
Module: Engine #1
Part #: Z03L906019JS 56
Component: BR4 20L EDC G000SG
Coding:
Fault codes:
0641: Rotor pos. sender in e-engine
Pending fault is not present. Pending fault has not been present during this driving cycle. Test is not running. Test is not inhibited by other DTC. Test has been completed. DTC validated and stored in non volatile memory. Validated fault present at time of request. Validated fault has been present during this driving cycle.
2008: Transmission Range Display, Circuit Short to Plus
Pending fault is not present. Pending fault has not been present during this driving cycle. Test is not running. Test is not inhibited by other DTC. Test has been completed. DTC validated and stored in non volatile memory. No validated fault present or fault has been validated as not present at time of request. Validated fault has not been present during this driving cycle.
026A: Digital TV-Tuner
Pending fault is not present. Pending fault has not been present during this driving cycle. Test is not running. Test is not inhibited by other DTC. Test has been completed. DTC validated and stored in non volatile memory. Validated fault present at time of request. Validated fault has not been present during this driving cycle.
Module: Transmission
Part #:
Component: not detected
Coding:
Module: ABS
Part #:
Coding: 600114B600C492900FF881406E9921B0042310000
Module: Passenger Seat
Part #:
Coding:
Module: AC & Heating
Part #:
Coding:
Module: Central Electronics #1
Part #:
Coding:
Module: Airbags
Part #:
Coding:
Module: Steering
Part #:
Coding:
Module: Instrument Cluster
Part #:
Coding:
Module: Driver seat
Part #:
Coding:
Module: Radio/Sat Nav
Part #:
Coding:
Module: Comfort System
Part #: 7N0907530C
Component: J533 G
Coding:
Module: Radio
Part #: 1K0035164A
Component: LOW NAR
Coding: 6000500040004
Part #:
Coding:
Module: Drivers's door
Part #:
Coding:
Module: Front passanger's door
Part #:
Coding:
Module: Module 51
Part #:
Coding:
Module: Instrument cluster
Part #: 5K0920861A ªªªªªª
Component: KOMBI ªªªª
Coding: 0700
Module: Driver's door
Part #: 561959701 ªªªªªª
Component: TUER-SG FT ªªªª
Coding: 04B5
Module: Module 34
Part #:
Coding:
Module: Heater & Air conditioning
Part #: 7N0907426L ªªªªªª
Component: AC Manuell ªªªª
Coding: 0000000002AAAAAAAAAA
Module: Engine
Part #:
Coding:
Module: Module 3B
Part #:
Coding:
Module: Module 52
Part #:
Coding:
Module: Steering wheel
Part #: 5K0953507ATªªªªªª
Component: Lenks.Modul ªªªª
Coding: 1080140000AAAAAAAAAA
Module: Airbag
Part #:
Coding:
Module: Module 6F
Part #:
Coding:
Module: Module 6D
Part #:
Coding:
Module: Module 73
Part #:
Coding:
Module: Module 6B
Part #:
Coding:
Module: Immobilizer
Part #: 5K0953234 ªªªªªª
Component: IMMO ªªªª
Coding: 0000
Module: Module 54
Part #:
Coding:
Module: Module 0B
Part #:
Coding:
Module: Module 1A
Part #:
Coding:
Module: Module 6A
Part #:
Coding:
Module: Parking Steering assist
Part #:
Coding:
Module: Module 55
Part #:
Coding:
Module: Module 0F
Part #:
Coding:
Module: Module 1E
Part #:
Coding:
Module: Module 72
Part #:
Coding:
Module: Module 45
Part #:
Coding:
Part #: 561959702 ªªªªªª
Component: TUER-SG BT ªªªª
Coding: 04B4
Module: Module 33
Part #:
Coding:
Module: Module 34
Part #:
Coding:
Module: Module 23
Part #:
Coding:
Module: Module 4C
Part #:
Coding:
Module: Keyless Entry Component
Part #:
Coding:
Module: Module E5
Part #:
Coding:
Module: Module 1D
Part #:
Coding:
Module: Module 2D
Part #:
Coding:
Module: Module 47
Part #:
Coding:
Module: Module 57
Part #:
Coding:
Module: Module 4E
Part #:
Coding:
Module: Module 69
Part #:
Coding:
Module: Module 67
Part #:
Coding:
Module: Module 2C
Part #:
Coding:
Module: Module 13
Part #:
Coding:
Module: Unknown
Part #:
Coding:
Module: Steering Assist
Part #: Z1K0909144M 32
Component: EPS_ZFLS K. 70
Coding:
Fault codes:
0522: Engine Control Module
Pending fault is not present. Pending fault has not been present during this driving cycle. Test is running. Test is not inhibited by other DTC. Test has been completed. DTC validated and stored in non volatile memory. No validated fault present or fault has been validated as not present at time of request. Validated fault has not been present during this driving cycle.
0524: ABS Control Module
Module: Immobiliser
Part #:
Coding:
Part #:
Coding:
Module: Driver Door
Part #:
Coding:
Module: Passenger Door
Part #:
Coding:
Module: Rear Left Door
Part #:
Coding:
Module: Rear Right Door
Part #:
Coding:
Module: Radio
Part #: 1K0035164A
Component: LOW NAR
Module: CAN Gateway
Part #: 7N0907530C
Component: J533 G
Coding: 600352002
