Update
So since I don't have a solvent bath or a pressure washer, attempted to clean all the parts by soaking everything in a combination of Purple Power degreaser from Walmart, diesel fuel, carb cleaner, and water.... needless to say that just ended up being a huge mess... So I just went with the Carb cleaner, some rags, wire brushes, toothbrushes, and a bottle brush. I got most of the stuff cleaned, but have some questions:
1. I can't seem to get to the inside of the intake manifold to clean it, thinking I just need to find a longer bottle brush, but is there a better way to get to it?
2. I saw a good video on Youtube about cleaning the turbo and I'm worried about the fact that I may have gotten debris in it due to my inexperience at taking things apart. Do I risk putting it back on without cleaning, or do I take it apart and take my chances?
3. The Turbo has a larger section attached, I'm guessing that it's what people are referring to as the exhaust manifold. It's similar to the intake manifold, so same question applies; longer bottle brush to get to the inside?
4. I have read some of the other sections about the VNT actuator and how to test it, but have no clue what the tests are and how to perform them, do I need to test mine before putting it back on, or again, cross fingers and hope it's ok?
5. Is there a way to take the top off of the EGR valve and clean in there? I had this submerged in the gunk with the other stuff and now I'm worried that it may have junk in it that I can't see/clean... specifically the top piece with that copper nozzle and then underneath there seems to be another valve, almost like a butane port on a refillable lighter. Has black crud in it from the soaking, not sure how to get it out, tried the Carb Cleaner and a pick, but couldn't get all of it out.
6. What exactly is that black part on the side of the EGR valve for? Do I need to worry about calibrating/testing it?
As my profile states, I'm a newbie, not only to VW's and TDI's, but to working on cars in general. I bought this car because I was interested in doing all the work myself and was getting tired of getting ripped off by dealers/repair places. I also probably classify under the adage "a little knowledge is a dangerous thing" as I seem to be getting myself in more messes... I'm learning through this forum and Youtube and my Bentley manuals, so hopefully I get to the point where I don't make my situation worse...
Sorry for the long post, but any advice would be greatly appreciated!
