X@V
- Joined
- Dec 13, 2004
- Location
- Sherbrooke, Qc, Canada
- TDI
- B7 A4 V6 2.5TDI, MK2 frankentdi 2.0 16V TDI PD
AHU/ALH Eurovan T4, about transmission (2.4D trans on 4cyl TDI?)
I'm looking for a T4 TDI conversion for a friend.
Now he has a '94 T4 2.4D 5-cyl. We would like to put a TDI inside but the transmission ratios are horrible!
I was looking at the 02A trans... but I thing I couldn't put the engine inside because of the 15 degrees of the original 2.4D (not sure if the engine's head would clear the firewall)
If I can't, is it possible to swap the 5th gear like on the 02A? Is it the same as a 02A? I actually have a '93 Passat TD 02A transmission with the 0.756 5th gear, but we could put a longer 5th gear (diff ratio is 4.7 I think), maybe a .658 gear would be nice...?
