rushtone
I'm a new 2009 SportWagen TDI owner (4 days so far), and a ham radio operator.
Any other hams out there with specific recommendations on installing ham gear in the car? I'm seeking advice on providing good power to equipment installed in the rear as well as installing a VHF/UHF dual-band antenna.
As a temporary measure, I've got a cig-lighter plug powering my APRS gear in the back, but would like to do better (at least tap a feed off the wiring going to the cig lighter, if not run a big fat pair of wires from the battery).
In the vehicle we traded in I had drilled a hole in the roof and had a permanent NMO mount there. Worked great, didn't have any wires going through door or hatch gaskets, and didn't have to worry about mag mounts scratching the roof. I've got the monster sun roof with retractable sunshade, so I'm not sure how much room there is between the headliner and the sheet metal in the back should I decide to punch a hole for an antenna.
David, ky7dr
David, ky7dr
