Av8wkr
I have a 2000 NB. Was on the Freeway and she lost power and died. It has 130,0000 miles on it. First thing I did was drain Fuel filter. Had lots of water. Changed filter and drained fuel. Must of got a bad batch. Now I have a new filter and good fuel.....But the pump will only pump fuel to #2 and 3 injectors. And even them, the pressure seems low. Nothing to #1 and 4. Have fuel in return line pumping fine.
Seems like the injection pump is bad? Anyone know of a good place to get mine repaired or a relacement that is somewhat in line with not getting it up the a@$. Thanks
