Hi there,
I am a returnee to this forum! Although it has been a great amount of time since I had my AFN A4 TDI. Back then I had installed bigger .216 nozzles and had a remap and was quite pleased to move things from 105 to 155 bhp with 222 ft/lb torque.
I now have a 99 A3 8L with a AHF engine, tbh when I first go the car I wasn't thinking about modifying it as it does do 55mpg...But I wouldn't be posting here if that was still the case
Some background on the car; it runs perfectly and is now on 192k miles. After tracing down a few niggles when I first got it, it is making it's stock figure of 110bhp (or ballpark, tested with a phone app using weight and drag co-efficient and gear box loss but not telling the app what engine I had). Also the car has had the cambelt, water pump, pulleys and tensioners replaced.
Thank you for bearing with the boring bit above but I thought some of it may help.
Upgrade wise I would really like to get the car in the 200bhp area, although I am on some what of a budget and do not want to drop thousands into the car due to it's cost I do not mind spending the "right" amount.
My plan to achieve 200bhp would be as follows:
- Upgrade to Bosch .216 nozzles.
- Install a larger SMIC (I understand the larger core will help with ducting) or go the FMIC route, the benefit of the SMIC for me is stealth and using stock piping for the most part.
- Put a hyrbid turbo like this on http://www.ebay.co.uk/itm/Garrett-G...arts_Vehicles_CarParts_SM&hash=item20da5bd6fe
-Custom map to take advantage of the above.
Based on that can anyone think of any improvements? I was wondering if the .216 nozzles would be a bit limited?
Also is it necessary for me to do the hammer mod if I am getting a remap? If I remember right I think my pump is meant to be good up to 220bhp.
Thanks in advance
Lewis
Thanks in advance
Lewis
