spfrancis
Hey there, I took my car at a service shop to do basically 2 things: 1 was the DSG service, and the second was to change out the harness on the driver door. The main problem I was seeing was that my driver side door window was intermittent going up and down. I also had an issue with the door lock button on the driver side, wasn't really doing much. It would pretty much not control any of the doors to lock/unlock. I have been dealing with the door lock thing for 5-7 years, and the window issue for the last 2 months. I really wanted to address the window up/down issue.
They ended up keeping it for 2 weeks, which was concerning, but it was over the 4th of July so they were saying they were short staffed. When I got the car back last night, it looked like the window and the door seemed to be working on the short drive back home. WHen I started it up this morning, I got a service engine light, this morning, and at one point It looked like it was not shifting properly for a short period of time. I stopped and started it , and the shifting issue didn't seem to happen again for the remaining of the 3 mile drive back.
I put it to my vagcom, and here are all the codes I'm seeing:
It is worrisome, but I wanted to get some input:
There is a ton of stuff in here, and hard for me to decipher. I called Mike(little) at Fallon to let him know that there is something wrong with my car since getting it back. I sent him the codes that I'm seeing this morning.
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.1.0 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: 3VWST71K46M770875 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72 7D
00-Steering Angle Sensor -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H02--- Serial number: VWZ7Z0F3293938
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 64E97BF6A7BE096F1D-8030
3 Faults Found:
009572 - Turbocharger Boost Control Position Sensor Circuit
P2564 - 000 - Signal too Low - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 308113 km
Time Indication: 0
Date: 2000.00.00
Time: 19:00:45
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Lambda: -1.0 %
Absolute Pres.: 999.6 mbar
Absolute Pres.: 979.2 mbar
Duty Cycle: 101.6 %
000579 - Solenoid Valve for Boost Pressure Control (N75)
P0243 - 000 - Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 308113 km
Time Indication: 0
Date: 2000.00.00
Time: 19:06:10
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101000
Absolute Pres.: 958.8 mbar
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 308124 km
Time Indication: 0
Date: 2000.00.00
Time: 20:14:52
Freeze Frame:
RPM: 2394 /min
Speed: 70.0 km/h
Load: 78.8 %
Voltage: 13.68 V
Bin. Bits: 00101000
Absolute Pres.: 2029.8 mbar
Absolute Pres.: 1356.6 mbar
Readiness: 1 2 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 043 HW: 02E 927 770 AE
Component: GSG DSG 070 1126
Revision: 04507000 Serial number: 00000512090089
Coding: 0000020
VCID: 5187A222C80C8CC746-8004
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0021122
VCID: 71C702A2684CACC766-8024
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 EC
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 69F76AC2409C54072E-803C
1 Fault Found:
00532 - Supply Voltage B+
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000258893
Coding: 14018E234004180000140000001400000008730B5C
Shop #: WSC 06524 444 84983
VCID: 2A75D5CE851A9F1FE7-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 06524
3 Faults Found:
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 200
Mileage: 308113 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 8.75 V
OFF
ON
OFF
OFF
OFF
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 6
Reset counter: 200
Mileage: 308113 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.85 V
ON
ON
OFF
OFF
OFF
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 200
Mileage: 308113 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 8.20 V
OFF
ON
OFF
OFF
OFF
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7F3015079
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 39 AIRBAG VW8R 032 7900
Revision: 03032000 Serial number: 0038FD041326
Coding: 0013113
VCID: 3957FA8270BC24879E-806C
Subsystem 1 - Part No: 1K0 959 339 E
Component: BF-Gewichtsens. 006 0005
Subsystem 2 - Serial number: 6332MSME0D56450AE
Subsystem 3 - Serial number: 6342MSME0D7302759
Subsystem 4 - Serial number: 6351HSME09146038+
Subsystem 5 - Serial number: 6361HSME09134E425
Subsystem 6 - Serial number: 63727SME087E5D42D
Subsystem 7 - Serial number: 63827SME0843251D/
1 Fault Found:
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0010021
VCID: 78D13F860B36FD8FA1-802C
1 Fault Found:
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 952 L
Component: KOMBIINSTRUMENT 3HL 4312
Coding: 0023203
Shop #: WSC 09460 444 69780
VCID: 334BC8AA52D0DED754-8066
Address 19: CAN Gateway Labels: None
VCID: 558F5632BCE4E0E79A-8000
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 4312
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1K0 959 701 L
Component: Tuer-SG 024 24A1
Coding: 0000245
Shop #: WSC 98765 666 30737
VCID: 3753FCBA46A832F768-8062
5 Faults Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
01044 - Control Module Incorrectly Coded
005 - No or Incorrect Basic Setting / Adaptation
01552 - Motor for Central Locking; Drivers Door (V56); Lock
012 - Electrical Fault in Circuit
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal
00120 - Outside Warning Light/Door exit Light Driver Side
012 - Electrical Fault in Circuit - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AF
Component: KSG 0401
Coding: 137803281B09058F880F048051A0
VCID: 74C90BB6175E99EF8D-8020
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
4 Faults Found:
00930 - Locking Module for Central Locking; Rear Left (F222)
01038 - Central Locking Thermal Protection
000 - - - Intermittent
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Component: Tuer-SG 024 2377
Coding: 0001269
3 Faults Found:
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
01553 - Motor for Central Locking; Passenger Door (V57); Lock
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal - Intermittent
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio DE2 011 0015
Revision: 00011000 Serial number: VWZ4Z7F2105263
Coding: 0010400
VCID: 206137E6F326554FB9-8074
2 Faults Found:
00003 - Control Module
014 - Defective
01305 - Databus for Infotainment
014 - Defective - Intermittent
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
VCID: 3147C2A2A8CCECC726-8064
1 Fault Found:
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 3245CDAEADCAD7DF5F-8066
1 Fault Found:
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D7FDED2B4F4882702-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End-------------------------(Elapsed Time: 03:08)--------------------------
www.Ross-Tech.com
Coding: 0050078
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 308113 km
Time Indication: 0
Date: 2000.00.00
Time: 19:00:45
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Lambda: -1.0 %
Duty Cycle: 101.6 %
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 308113 km
Time Indication: 0
Date: 2000.00.00
Time: 19:06:10
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101000
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 308124 km
Time Indication: 0
Date: 2000.00.00
Time: 20:14:52
Freeze Frame:
RPM: 2394 /min
Speed: 70.0 km/h
Load: 78.8 %
Voltage: 13.68 V
Bin. Bits: 00101000
Coding: 0000020
Revision: 00H13001
Coding: 0021122
1 Fault Found:
1 Fault Found:
Coding: 00063445
Shop #: WSC 06524
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 200
Mileage: 308113 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 8.75 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 200
Mileage: 308113 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.85 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 200
Mileage: 308113 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 8.20 V
OFF
ON
OFF
OFF
OFF
Coding: 0013113
1 Fault Found:
Coding: 0010021
1 Fault Found:
Coding: 0023203
Coding: 0000245
5 Faults Found:
Component: KSG 0401
4 Faults Found:
Coding: 0001269
3 Faults Found:
Coding: 0010400
2 Faults Found:
014 - Defective
Coding: 0000144
1 Fault Found:
Coding: 0000144
1 Fault Found:
1 Fault Found:
014 - Defective
