Samg
Passat b5.5 2005 tdi 1.9 130 pd engine code AWX
Help! I have Spent weeks under car/ going cross eyed on internet etc.
ESP LIGHT comes on (SOLID) after 10 mins, goes out again after restarting. (Battery light works fine, car runs fine) Cheap code reader says engine 17911 and ABS 18265. In the past year its had a new battery, alternator and break pedal switch. Looking on other threads, Skoda’s/golfs etc. say Alternator load wire may be broken in engine bay. Mine has two thin blue wires going from alt( lamp and digital field monitoring) into wiring loom through bulkhead (i think). Should I be looking for a broken wire/connector and if so where? I’ve been searching around starter motor with no luck, is this even a known issue with Passat’s? Currently have black tape covering warning light......lol!
