courtpassat
The top hose popped off twice now (see pic). The nubs aren't worn but the clip has snapped. I found 2 types on ebay, not sure which one I need (one has the pins reversed). Also I can't find a website with parts diagrams anymore (where it will break down the entire car and show every part number code for each bolt/clip etc.
https://i.imgur.com/p9xghAO.jpg
https://i.imgur.com/sWfnIs0.jpg
It's the hose connection next to the dipstick and coolant reservoir.
Also What is the part number for the pipe that goes behind the engine (with sensors plugged into) as the end of it where the hose blew is a bit cracked, so I'm not sure if replacing just this clip will secure it.
Thanks in advance.
Thanks in advance.
