Old February 1st, 2014, 20:08   #1
Turbo_Boss
Turbo_Boss's Avatar
Default Inexpensive suction device for differential oil
Hey guys,
I am going to replace the differential fluid on my automatic transmission (01M)
I have read some people use a oil suction device like the Pela or Mityvac 7400 to suck out all the old differential fluid but I found on e-bay this "inexpensive" oil suction device: Wel-Bilt Manual Oil Extractor Model# KXOE-002 for $8.49
Have any of you has experience with this model? I really dont want to spend to much on a Pela/Mityvac
THX
Turbo_Boss is offline   Reply With Quote
Old February 2nd, 2014, 16:50   #2
AndyBees
AndyBees's Avatar
Admittedly, I have Zero experience with the 01M auto tranny, but seems the drain plug would/should be at the lowest point in the diff. Thus, it should drain out just fine without the use of suction!
This is the TDI Club, a place to share experiences & ideas, ask for help, etc. Welcome Newbies! Sarcastic and condescending posts shouldn't be welcome.
Old February 2nd, 2014, 17:14   #3
Turbo_Boss
Turbo_Boss's Avatar
The 01M auto tranny use a separated oil container for the differential. There is a drain plug for the automatic fluid but there is no drain plug for the differential oil.
I need to remove the speed sensor and thru that hole I can take out the differential oil with a suction device.
THX,
Isaac
Old February 3rd, 2014, 05:46   #4
CNGVW
Location: Bob Mann Auto, 111 High St, Pembroke MA 02359
Fuel Economy: Built a 2002 TDI Jetta that got 120 mpg of diesel using a CNG blend.
I would use the better build ones like one bellow you will end up using it for many other things.
Bob Mann Auto
Bob Mann
www.DRVOLKS.com
bobtec@comcast.net
VW and Audi Master Technician and TDI Specialist. Bob has over 35 years of experience in the field, and is listed on TDIclub.com as a trusted TDI Mechanic.
Bob is also known for his CNG conversions and is a consultant for Patrick Racing.
CNGVW is offline   Reply With Quote
Old February 3rd, 2014, 05:49   #5
dieseldorf
top post dawg
dieseldorf's Avatar
Hardware Fright sells some really cheap suction devices...so cheap you could throw it away when you're done with it. If you can find a coupon for it, it's probably $4 or something close to that.
Old February 4th, 2014, 04:30   #6
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
there is no drain plug on the 01m differential.
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old February 4th, 2014, 12:01   #7
dan kerkstra
Fuel Economy: unk trans is on floor
Hey Andy I like the hat dude
dan kerkstra is offline   Reply With Quote
Suction device for oil draining Laith TDI 101 12 November 10th, 2007 16:12
Oil suction pumps suck!!! Jimbo70 VW MKIV-A4 TDIs (VE and PD) 11 June 19th, 2004 19:55
Oil Change - suction Tool txg60 VW MKIV-A4 TDIs (VE and PD) 4 July 11th, 2002 00:59
Oil Changes: Drain or Suction? Dante Fuels & Lubricants 31 May 29th, 2002 07:48
Topsider suction device rocks for NB oil changes sfierz VW MKIV-A4 TDIs (VE and PD) 13 April 1st, 2002 00:51
Page generated in 0.15646 seconds with 11 queries
[Output: 81.54 Kb. compressed to 70.92 Kb. by saving 10.62 Kb. (13.03%)]
