Old April 12th, 2011, 04:55   #1
dchapman
Default New turbo installed question
I recently punctured my oil pan and despite stopping within a couple hundred yards my turbo was wasted. I have little faith in the shop that installed the turbo, and now they are going to have it again. Since the new install, 1) the powerband has shifted higher from about 2700-3600, 2) I now hear the turbo thru that entire range, 3) don't seem to have as much low end power (i.e. 1300-2000 rpms), and 4) now the engine runs but seem to have lost the turbo.
Any guesses as to what these symptoms are caused from? Any suggestions as to what I can have the shop start on? And yes I know, I need to find a good mechanic! Thanks!
Chap
2003 New Beetle TDI
dchapman is offline   Reply With Quote
Old April 12th, 2011, 05:55   #2
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
Improperly adjusted vacuum actuator on the VNT mechanism would be the first guess. The actuator should start to move at 3-5 inHg and hit the stop screw at 17-20 inHg. DO NOT ADJUST THE STOP SCREW - only the actuator rod itself.
If none of this makes any sense to you or your mechanic - find a different mechanic. There are quite a few good ones "out east". Someone will chime in on who is in your relatively local area.
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
I installed new turbo; now I boost 0psi.. ***? 85_305 TDI 101 12 August 29th, 2010 13:59
New Turbo installed but car isnt right! jcrad TDI 101 17 December 17th, 2009 22:23
Do any VW TDI's come without a turbo installed? ScottRotman TDI 101 14 October 20th, 2009 04:49
new turbo gauge installed stronzo TDI Power Enhancements 33 July 29th, 2007 14:59
Turbo Installed-Car Running gottdi TDI 101 0 January 7th, 2007 13:56
Page generated in 0.13536 seconds with 11 queries
[Output: 55.08 Kb. compressed to 51.04 Kb. by saving 4.04 Kb. (7.34%)]
