Old March 13th, 2018, 12:47   #166
jokila
jokila's Avatar
Fuel Economy: 52/45/40
Originally Posted by runonbeer View Post
I think they’re asking about the bolt that secures the axle flange to the differential on the gearbox. I don’t know the exact value but off the top of my head, it is in the 18 ftlb range.
Gotcha. THAT part of the flange.
It only has to hold it on the splined shaft so 18 ft lbs sounds enough. The bolt looks no bigger than bolts which are torqued 15-20ish in general.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is offline   Reply With Quote
Old April 21st, 2018, 12:49   #167
muzy
TDI(s): 02 jetta TDI
Fuel Economy: in process
Smile
Originally Posted by SilverGhost View Post
That's actually a rule of thumb, not a hard/fast rule. And we techs give the parts guys a hard time as they generally know less about the car then we do. But, when you are replacing the one use bolts, did you ever notice that they all were green? Well, 99% of them anyway.
This is just another case of "a little information is dangerous". Junior tech heard most green bolts are one use so he made asumption (as you me ) they all are.
Its been quite a while since I did parts, but with the red and green thing. Seems to me had more to do with thread pitch than anything else.
Cheers
muzy is offline   Reply With Quote
Old May 1st, 2018, 20:07   #168
joshwho?
Does anyone know the torque value for the oil pump mounting bolts?
I read through and didn't find it hidden anywhere.
Thanks!
-Josh
joshwho? is offline   Reply With Quote
Old May 2nd, 2018, 11:23   #169
Nuje
Fuel Economy: 1250km/tank
Looks like 23nm
Nuje is offline   Reply With Quote
Old Yesterday, 12:35   #170
wmkornblum
Default Same
Originally Posted by 57ringo View Post
Does anyone else feel like their Bentley manual is a very poor manual for providing information? It always seems like what you want to know isn't listed. whether it be torque specs or proper procedures. I thought some of the service manuals were poor for my tractors and trucks but this thing is by far the worst.
It's lacking a lot of information
wmkornblum is offline   Reply With Quote
Old Yesterday, 12:48   #171
wmkornblum
Default Subframe to Body bolts
What is the torque for the subframe to body bolts
Old Today, 13:09   #172
rotarykid
rotarykid's Avatar
Fuel Economy: 64 .1city @ 30-60 mph/ 52-53 @ 70-85 mph hyway ( 52 to just under 60 normal around town)on LSD
Arrow bentley manual are written specifically for well trained mechanics
Originally Posted by wmkornblum View Post
IOriginally Posted by 57ringo View Post
In my decades of experience, I have found the bentley manuals are more than adequate when it comes to needed info for repairs if you are a well-trained mechanic.
The problems start for someone who needs all steps laid out for them to make the repair, like are given in chiltons & similar, the steps that the bentley manual writers assume the mechanic using their manuals do not need spelled out for a successful repair....
If you are having trouble using the bentley manuals I with all due respect suggest taking a refresher mechanic class at a local college to fill in the gaps one who is using a bentley manual is having using it to make the repairs they want....
With my over ~40 years at this point making repairs to all sorts of engines from tractors, boat engines, car engines, suspensions....ect... I find the bentleys plenty useful when carrying out repairs....
I will add that well-trained mechanics in my experience find the chiltons & similar manual to be too filled with what is useless to us details that we all know by heart. It is too cluttered making looking a particular detail we might need take longer than is required, with many times we find the one detail we might need to look up at the time having been left out because the writers of these manuals assume the detail we need is over the head of the shade tree mechanic who is the in the market to purchase their manual.....
More diesels than I can list
rotarykid is offline   Reply With Quote
Page generated in 0.12307 seconds with 10 queries
[Output: 80.79 Kb. compressed to 70.37 Kb. by saving 10.42 Kb. (12.90%)]
