L Linkbad21 Member Joined Jul 5, 2016 Location gervais Oregon TDI 2010 vw jetta Tdi Jun 2, 2018 #1 Hi im looking for someone with a Vag-Com so i can prime my 2010 VW TDI
jokila Vendor Joined Dec 3, 2004 Location Houston, Texas TDI 2003 Jetta GLS, Manual Jun 5, 2018 #2 http://www.maptive.com/ver3/VCDS_Locator
Powder Hound Top Post Dawg Joined Oct 25, 1999 Location Under a Bridge, Crestview, FL, USA TDI '00 Golf 4dr White 5sp, '02 Jettachero 5sp, Wife's '03 NB Platinum Gray auto(!) Jun 6, 2018 #3 I have one, but since the commute is rather lengthy I suggest you use the map Jokila so kindly posted. Or maybe a note in the regional forums? Cheers, PH
BobnOH not-a-mechanic Joined May 29, 2004 Location central Ohio TDI New Beetle 2003 manual Jun 6, 2018 #4 Keep in mind the VCDS (vag-com) is used with the gasser as well, so regional VW forums is an excellent suggestion.
