Bradtholomew
I put in a Valeo/G60 kit about 100,000kms ago and it's slipping badly in all gears now. I'm going to get a VR6 clutch, should I replace the flywheel as well?
Brad
Brad
Yeah, the kit I'm getting (and should've got in the first place) is the Sachs clutch, different than the Valeo. According to some vendors, the Valeo is rated to hold 270 ft-lb and the Sachs 300 ft-lb.Toronto_Vento said:Why is it slipping like crazy with the G60 setup? I thought the Valeo setup used a VR6 clutch and a G60 flywheel. Or am I thinking of a different kit?
Myth. Don't care what anyone tries to sell you on. I've had a Sachs slip at 250 ft-lbs with a NEW flywheel properly broken in.Bradtholomew said:According to some vendors, the Valeo is rated to hold 270 ft-lb and the Sachs 300 ft-lb.
