Old October 24th, 2017, 06:02   #271
lovehandles18
Talking Just Installed CP3...Nice!
Add me to the list!
I had VL Performance in Appleton WI do the work and the pump is a beast. I've burned about 1 full tank of diesel with the new pump and I'm getting better fuel mileage than I ever have before, which is weird as the temps here have dropped into the 40's/50's which usually decreases efficiency.
The tune seems a bit stronger as well (Malone stage 2). Just a little more pull through the gears.
Feels good knowing my car is prepped for the long haul after deciding to skip the buyback
lovehandles18 is offline   Reply With Quote
Old October 24th, 2017, 06:43   #272
2micron
TDI(s): None
That's wonderful!
Congrats and many happy miles ahead.
Andrew
2micron is offline   Reply With Quote
Old October 26th, 2017, 06:30   #273
voilsb
Originally Posted by ksing44 View Post
Good news for people with the CP3 that want the fix. I got the fix yesterday and the dealer didn't say anything about the CP3 pump and not having an auxiliary pump. The adviser said they looked hard to find anything wrong with my car, but they couldn't find anything and said my car was in great shape. They were also amazed how clean my car was, considering it has over 153,000 miles. I'm a neat nut.
Of course that doesn't settle worries about warranty after the fact, but at least I'll have my check for the fix.
Good to know!
Sent from my F5321 using Tapatalk
voilsb is offline   Reply With Quote
Old October 27th, 2017, 11:39   #274
travis45
travis45's Avatar
Coty from VL Performance is the guy who flashed my Malone stage 3 in. Glad to hear it's working well!
Originally Posted by lovehandles18 View Post
Add me to the list!
14 Sportwagen TDI CR170 Frankenstien hybrid 2056 Turbo, Rawtek turbo back exhaust, Malone Stage 3, CP3 Fuel Pump, Malone DSG Tune, Panzer, 19" Konig Oversteer Wheels, Fluidamper Crank Pulley, H&R 22mm rear sway bar, PolarFIS. Soon to install Darkside intercooler and piping, Wavetrac LSD.
travis45 is offline   Reply With Quote
Old February 14th, 2018, 17:37   #275
voilsb
For the record, it wasn't actually fixed. Ran through a lot of troubleshooting after this post and the problem kept coming back. Turns out the engine electrical harness was wedged behind the throttle body, worn through, and shorting out. Replaced the harness and zero problems for over 2,000 miles now.
Originally Posted by voilsb View Post
FIXED! Andrew was immensely helpful!
Short version, the aux pump from the old HPFP shorted out, which blew the fuse controlling the lifter pump. Eventually fuel stopped getting to the engine, and she starved. Pulled the aux pump, cleared the air out of the fuel lines, and she runs like a charm!
Long version is posted at http://myturbodiesel.com/threads/tro...-system.30965/
Old February 14th, 2018, 18:07   #276
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
Glad you got everything sorted out! I bet you were a little mad when you discovered the harness short. Reminds me of a few times when I was trying to track down the cause of "intermittent" fault, lol.
2010 4D CWhite Golf TDI, 6 sp manual, Fluidampr, Bixenons, Rear Airbags, RNS-510, Dynaudio, DieselGeek SS & P2015 bracket, Force Fed Eng. Shifter Bushings. XB,UB, & RB UNIbraces; TyrolSport Brake Caliper Bushing, 2Micron Contain/PureFlow kits & timing belt cover, PolarFis MFD module, Euro light switch, R Red LED Tail Lights,Under Seat Drawers, Full color MFD cluster.
bobt2382 is online now   Reply With Quote
Old May 21st, 2018, 12:36   #277
Odyssey
Hello. After installing the CP3, a rumble appeared in the area of the fuel hoses in the range of 1200-1900 rpm. Passat 2.0 CBAB The additional pump has been removed.
Odyssey is offline   Reply With Quote
Old May 21st, 2018, 17:38   #278
Owain@malonetuning
Rumble? does it drive smooth? best to data log rail request vs actual to see if there's any oscillations.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is online now   Reply With Quote
Old May 22nd, 2018, 13:06   #279
Odyssey
There are no errors. works smoothly. Rides well. noise from the hose fuel filter pump, pump-fuel filter.
Old May 24th, 2018, 01:53   #280
ksing44
I can't help with the rumble, but I wanted to let everyone know that I didn't have an issue with a warranty repair after the fix even though I have a CP3 pump. I got the P2015 code and VW provided a new manifold under the extended warranty after the fix.
Another note, my dealer didn't think the manifold was covered under the extended warranty, but they called VW and were told that yes it was! My dealer said they have over 200 pages of information about the warranty and sometimes it's hard to figure out what's covered. I guess it's best to always ask your dealer to check with VW if you think you have a repair that should be covered by the warranty!
2010 Golf TDI - Blue (BGM), 4-Dr, 6-M, Sunroof, Xenon, Dynaudio, Nav (RNS-510), Euro light switch, 9W7 BT, R Tinted LED Tail Lights, Monte Carlo 17" x 7.5" ET47 Wheels, 235/45/17 Tires, P3Cars Digital Interface, Sonniboy sunshades, CP3 HPFP!
Flickr slideshow
ksing44 is offline   Reply With Quote
CP3 Pump Install Experiments.**Big Picts** 2micron VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 410 November 11th, 2016 07:38
CP3 Pump on a 09 JSW Paulinski VW MKV-A5 Golf/Jettas 15 September 10th, 2015 07:35
Another fuel pump failure thread dborja VW MKVI-A6 Jetta Sedan (~ 2011+) 83 May 21st, 2013 12:43
Fuel pump upgrade needed with turbo upgrade? (AHU) mk3tdi1996 TDI Power Enhancements 42 January 9th, 2011 15:15
Page generated in 0.15145 seconds with 12 queries
[Output: 99.64 Kb. compressed to 85.39 Kb. by saving 14.25 Kb. (14.30%)]
