jonsaxbiz@gmail.com
I have a question about the TDI clutches? Or I guess Jetta clutches in general because they are probably the same or similar in the Jetta GL versions. Anyway, I'm having NO PROBLEMS at all shifting and the clutch is gripping totally fine. No issues with actually driving etc. BUT... when I'm idling and in neutral, if I release the clutch, I can hear some noise, like maybe a noisy throw out bearing or something. I just sounds like gears turning. Does anyone know what this is about? Is this expensive to fix? Do I have to replace the whole clutch or is it possible to replace JUST the part that is noisy, like the throw out bearing? I'm pretty sure there must be some sort of problem because my buddy's TDI doesn't make any noise when his clutch pedal is out.
any thoughts???
any thoughts???
