rmorton102
Hi, I’m a Newby to the forum. I purchased a 2004 Jetta TDI GLS 5 sp. with 73,000 miles last June. I have a small complaint that I have not seen listed on the forum. (I’ve been a member since my purchase.) My complaint is, the cranking time is less than one second when cold. When hot the crank time is 2-3+ seconds. I followed a thread that I saw on the forum to a web site sponsored by VW to familiarize mechanics with the PD engine. One of the features of the PD engine is a “Quick Start” feature. This is accomplished by using the camshaft position sensor and the crankshaft speed sensor to determine the relative position of each cyl. piston to the compression stroke so that the appropriate injector electro valve may be energized thereby starting the engine. Should the cam shaft sensor fail, the engine will continue to run/ (start ?) using the crank shaft speed sensor alone to determine the appropriate piston position, however if the crankshaft speed sensor fails the engine will fail to start/run. Because the engine always starts & runs fine, it appears to me that I may have a partial camshaft sensor failure or restriction of signal to the ECM only when heat is present. I have seen no codes on the dash display. I am going to apply Stabalant 22 to the cam sensor connector and see if that helps. If anyone has any information on this issue, I would sure appreciate it.
Rmorton102
Rmorton102
