neimis
- Joined
- Dec 12, 2000
- Location
- Victoria, B.C., Canada
- TDI
- '92 Passat TD, '01 Golf GL TDI, '15 Golf Trendline TDI
Okay, I tried sucking the oil out using a drill pump, but at first I couldn't even get the pump to draw up the oil. I finally got some in the tube by sucking with my mouth
(blechh, at least I didn't ingest any!!) and then it started dribbling out into the used oil container. I pumped (or drilled, as it was) for an eternity. It took about 10 min to get a couple of litres. At that point I gave up in disgust.
I changed the oil filter and managed to suck up the oil at the bottom of the oil cooler, but that took a very long time. I don't think it's supposed to be this difficult, is it?
I have a powerful hand drill (Milwaukee Magnum) and used a copper tube for inserting into the dipstick. The hole, after using a tubing cutter on it, seems awfully small - could this be the problem?
Also, when I tested the pump by holding my finger over the end of the tube to see how much vacuum it was creating, it seemed very weak.
The oil was warm, and flowed easily.
I like the idea of pumping the oil out (keep it neat) and also of getting it out of the oil cooler, so I'd like to see if I can get it to work before I give up and buy a Topsider or somerthing similar.
Any ideas or advice appreciated.
