turbodan62
what is a low cost up grade for this TDI .. Not a race car just a little more go -power Thanks Tdan
How do you feel about their Fr/R sway bar kits? What is the general consensus going Fr/rear vs. just the rear? I understand it's about balance, but both bars are adjustable IIRC.factor it about $700 if you get the flashzilla which is worth it.
Also rear sway bar makes it way more enjoyable, H&R 24MM bar on our SEL ($280ish).
Also check out US vendors such as KermaTDI for carb friendly tuning that keeps your car out of spotlight until the EPA cools off..
We had a '12 passat with stock bar for 80K, I had only a rear 24mm bar on the Jetta for 120K (30K at soft, remainder on stiff).How do you feel about their Fr/R sway bar kits? What is the general consensus going Fr/rear vs. just the rear? I understand it's about balance, but both bars are adjustable IIRC.
