Cburb88
I went to drive to lunch today and noticed my turbo was real loud, its usually noticeable at idle and driving slow because of the stage 4 tune and it being a VNT17 but it was way louder than normal, noticed it had low power also. Then after about 2 mins all the sudden the loud turbo noise went away and it sounded back to normal had good power, driving back from store it was the same thing good power and everything, left work still normal. The turbo isnt old at all, when i bought like a year ago the turbo looked brand new.
Went to drive it after work and its loud again, whirling turbo noise like a straight piped 6.0 ford or worse, no power and hazy out the exhaust, this time it seems like its not going away, then i notice its also like a buzzy vibrating sound coming from either the wastegate area or exhaust side of turbo when i put my hand on it running. If i unplug the wastegate hose the actuator shaft drives back down and the sound goes away, but when revving it still doesnt sound right, so far ive pulled intercooler boot and pipe off and theres coatings of oil inside but no liquid amounts poured out or anything, took the turbo inlet off and i can turn the wheel by hand and dont feel any roughness or rubbing at all, dont notice any damage. Pretty confused at whats going on and no codes, not sure if VCDS would tell me anything it seems pretty mechanical.
