detroit rims on a 2014 passat tdi SE
enatman
PA
current 2006 brm, 2014 passat SE returned, 2000 jetta 404k (sold)
Just curious if this rim is compatible? I checked size and it works, 5x112 bolt pattern, but the tires seem to be smaller..Not sure if this will be a normal fit? or need a spacer..OR will look stupid? (I have 18" bristol)
I have a little road rash (bristol) and bounce on 2 of the OEM bristol rims that came with the car. I liked the look on other VW's of the detroits, as opposed to paying full price to replace the bristol rims I found a set of 4 "Detroit's" like new for $350
Will the fit identical to oem Bristol?
Has anyone used these on their b7? happy? complaints? pics?
I'm NOT concerned with clearance as I'm keeping the same size
JM Popaleetus
Connecticut
Signature.
All VW rims that use the 5x112 bolt pattern are ~for the most part~ interchangeable between models.
That said, with the Passat, you'll need 17" for caliper clearance; Detroits will work fine.
Trvln Canuk
Brantford, ON
2013 Passat TL TDI
I have 16" on my 2013 Passat and they clear the calipers just fine. The 16" are standard on the Trendline model in Canada.
MichaelB
SE Wisconsin
2014 Passat SE DSG
I have been running 16" steelies with winter tires for two seasons now. Never a caliper clearance issue. 2014 Passat SE 18" factory rims came on the car.
BKmetz
Administrator, Member #10
Staff member
Illinois
2015 Passat, titanium beige, 6MT
My Passat SE came with 17" wheels and I got rid of them. I have 16" steel wheels from a Passat S for my winter tires and 16" alloys from a Wolfsburg Edition Passat for my summer tires. Both clear the calipers just fine.
MichaelB
SE Wisconsin
2014 Passat SE DSG
JM Popaleetus
Connecticut
Signature.
If the base gassers models are standard with 16" wheels (the calipers are the same) why is that too close for comfort? What comfort are you looking for? I have seen that post before. In the end it was found that the wheel weights were misplaced. Nothing wrong with 16" wheels many Passats use them.
I prefer a little more clearance. Especially with how bad our roads are here, and our winters.
Good to know that 16" do in fact mount.
enatman
PA
Thanks for you input..I'm NOT looking to reduce tire size... I'm sticking with 18s
enatman
PA
I put on jetta 16's and they work great...made sure we got the circumference right on tires....just like having AWD...not pretty but very functional
