Timing Belt interval
Niner
duplicate account, banned
Does, or has anyone looked into their owners manual for service intervals recommended for timing belts on this new model? Is it 120k mile, 130k miles, what is stated in the booklet?
Just curious, want to know the potential maintenance expenses up front, long term for this car.
Niner
My manual, now that I own one, says 130k miles for the timing belt.
MyAvocation
Hoffman Estates, IL
2017 Passat SEL TSI
Here we go again... Same TDI motor, two different CIs published. The OM in my 2006.5 says do TB at 80k and 100k. Never had the opportunity to ask VW why 2nd TB only good for 20k. ;)
oilhammer
outside St Louis, MO
The B7 Passat TDI manual says 130k... which is 10k more than the similar engine in the Golf and Jetta.
Given the robust build of the belt used, I would bet it could even go longer... but I would not recommend that.
Niner
Around here it usually costs many thousands of dollars, since shortly thereafter you'll need a valve job. :rolleyes:
It costs about $800 here, done correctly.
Cool, can we look forward to an Oilhammer step by step write up like the Drivbiwire procedures provided here on TDI club? :cool:
740GLE
NH
for the CEBA but the CRKA or whatever the passat has should be 95% identical.
oilhammer
Done a couple, not a bad job. Some folks have done quite a few. We charge 4.5 hr (same as the BEW) for the whole job.
For comparison, our labor is:
ALH: 5hr
BRM: 4hr
BHW: 5hr
AEG/AZG/AVH/BEV: 3.5hr
ATQ: 5.5hr
AWM: 4.5hr
AWW/etc. 4.5hr
So the CBEA/CJAA is not too bad.
Niner
ALH: 5hr
BRM: 4hr
BHW: 5hr
ATQ: 5.5hr
AWM: 4.5hr
AWW/etc. 4.5hr
And the AHU is ?
