Go Back   TDIClub Forums > Picture Gallery/Specs of Members' TDIs > Other TDI/Diesel Picture Gallery
Other TDI/Diesel Picture Gallery Do you have a TDI or Diesel not listed above? If so write a message here describing it and insert a picture if you have one. If you don't have one on the computer, email me and I'll give you my address and I'll scan it for you. If you need web space for it, email me as well. Please make a short yet descriptive title for your vehicle.
Old November 24th, 2018, 20:44   #61
3L3M3NT
3L3M3NT's Avatar
It seems like winter has started here as well, minus the little warm up we had yesterday and today. I can imagine now with winter tires you'll really be looking forward to what the car can do once you get a decent amount of snow. I'm sure having slightly taller tires will help a little bit with clearance.
I'm looking forward to seeing some new pictures of your car busting a path through the snow.
Fix if you're using Chrome: Chrome fix
Firefox fix
RTDI Build Thread
October 19th,2019 Cruise/GTG in Sturgeon Bay, WI
3L3M3NT is offline   Reply With Quote
Old January 18th, 2019, 10:47   #62
nokivasara
nokivasara's Avatar
Fuel Economy: 44-49 mpg
Still not enough snow to cause any excitement but that's nice for a change, makes my job easier.
Really happy with the taller tires, been getting 37-38 mpg with studded tires, if I did the math right when calculating the difference in tire size. Seems like the odometer reading didn't change when I calibrated the speedometer for the larger tires so the distance reads 2-3% too low.
nokivasara is offline   Reply With Quote
Old February 5th, 2019, 08:34   #63
nokivasara
nokivasara's Avatar
Despite the Skoda Octavia mk2 being based on a mk5 Golf there are some areas that differ quite a bit. The boot space is one.
Here's how mine is laden most of the time:
*chainsaw
*snowshovel
*jumper cables, tow line and misc tools in the black box
*clothes and istruments needed in my work as a forester. Blue box
*a box of flagging tapeš
*snow shoes
*first aid kit
*50l backpack
*an axe
*misc small stuff
In the summer an insulated cooler for food and water.
All this with room to spare!
Old August 16th, 2019, 13:28   #64
nokivasara
nokivasara's Avatar
No new pics but it has rolled over to the 300k km side
Have some service planned, rear diff, haldex and timing belt to start with. I'll change the t-stat too, I think the temp was a bit too low last winter.
Old August 16th, 2019, 14:17   #65
casioqv
This is such an incredible car, I also wish we had something like it in the USA. The Touareg TDI is the closest thing, but is comparatively big, complicated, and heavy.
Originally Posted by nokivasara View Post
It's not a skid plate but it does add protection to the fuel lines and the floor itself from stone chips and such.
On my TDI Golf I always worry about that fuel cooler... it seems extremely vulnerable, and could lead to running out of diesel in a remote place if punctured.
2001 Golf TDI - 02m 6 speed swap; +ASR/EDL; panzer plate
2009 Touareg 3.0 TDI
casioqv is offline   Reply With Quote
Old August 20th, 2019, 12:40   #66
Quade
Skoda Octavia is one of my favorite car. I love to see your car but can't find its picture. Please share its picture.
copymachinereviews.com
Quade is offline   Reply With Quote
Old November 25th, 2019, 10:40   #67
nokivasara
nokivasara's Avatar
Yes, the Octavia is much smaller than a Touareg, it's basically a mk5 Golf, which is good when we have one of each. I only need to learn how to work on one to fix them both
The fuel cooler location is nuts, I have thought about making a steel skid plate that covers it. Even better would be to relocate it to the front or maybe the firewall area...
Old November 25th, 2019, 10:42   #68
nokivasara
nokivasara's Avatar
Photobucket ate my pictures, there are some in the last pages of this thread. More pics to come
Old November 26th, 2019, 09:20   #69
nokivasara
nokivasara's Avatar
Took some pics of todays tinkering with the mighty Skoda, sorry for the low quality, my phone is showing its age...
First a comparison with our mk5 Golf, a bit unfair since they aren't on level ground. I may set them up on a parking lot sometime for better pics.
Then I went on to mount my cabin heater on the side of the centre console panel. That's pretty much standard up here, everyone has one, they are in series with the inline coolant heater and gets power from the same outlet.
I removed the side panel to check that there weren't any wires behind it. Apparently I didn't get a picture of the mounting hardware
Lastly a picture from the source of an water leak I've been chasing for a while. I get a puddle of water on the trim inside the door opening after heavy rain and thought it was from the door seal but today I found out that it came from the inside of the door card!
Drilled out the rivets on the bottom of the inner door panel and found that the seal was in pieces. Did a temporary RTV sealant fix and called it a day.
Old January 3rd, 2020, 12:10   #70
nokivasara
nokivasara's Avatar
Did a bit of a new-year service:
*oil change in rear diff and Haldex unit
*timing belt
*t-stat
*RH side droplink
Old January 4th, 2020, 09:39   #71
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
Nice idea. Never seen those before. How "warm" is the cabin when you get in to drive? Nice to see its treating you well!
[/url]
[url=http://pics.tdiclub.com/showphoto.php?photo=133455&title=img-20191126-100221&cat=6834]
2010 4D CWhite Golf TDI, 6 sp manual, Fluidampr, Bixenons, Rear Airbags, RNS-510, Dynaudio, DieselGeek SS & P2015 bracket, Force Fed Eng. Shifter Bushings. XB,UB, & RB UNIbraces; TyrolSport Brake Caliper Bushing, 2Micron Contain/PureFlow kits & timing belt cover, PolarFis MFD module, Euro light switch, R Red LED Tail Lights,Under Seat Drawers, Full color MFD cluster.
bobt2382 is online now   Reply With Quote
Old January 4th, 2020, 10:12   #72
nokivasara
nokivasara's Avatar
The heater is 550W in LO and 1200W in HI setting so it gets pretty toasty unless it's really cold out. The coolant heater is 500W I think.
octavia 1.6 tdi kylobeddo General Automotive 0 August 14th, 2014 07:50
2008 Jeep Laredo 4x4- trade for a TDI! TDI_01 TDI Cars for Sale/Wanted 7 October 27th, 2010 15:42
octavia tdi goes nuts far_cry TDI 101 4 December 30th, 2009 14:18
Car and Driver: 2008 TDI Jetta named one of 2008's most fuel efficient surprises Tahna Los TDI News/Tech 162 February 3rd, 2008 15:50
Skoda Octavia TDI's Stateside? Arcturus VW MKIV-A4 TDIs (VE and PD) 9 June 7th, 2000 03:02
Page generated in 0.20155 seconds with 13 queries
[Output: 119.03 Kb. compressed to 101.26 Kb. by saving 17.77 Kb. (14.93%)]
