Spring Rates? Please Comment!
I spent some time last night digging around the interwebs (now you know how exciting my life is) for info on setup for my Golf for this coming track season. I have Koni Coilovers, and last year ran 550F/350R springs, no front bar, and a Shine race rear bar, which is very stiff. This is how the car looked at race height.
I was running about -2 degrees camber in front, using Ground Control Camber plates, and I didn't play with rear camber. The car would push a bit, but not a ton. And it barely lifted an inside rear wheel on corners, nothing like it did with the Shine setup.
After I wrecked the Golf I ran IBW with the same coilovers, but first with 550F/700R springs (that's right, 700), and then with 700F/550R. It also has a Shine bar, but not a race one. And I disconnected the front bar. I tried the stiffer rear springs at the recommendation of a guy who drives a NB, who told me that with stiffer rear springs you'll get more rotation. I honestly couldn't feel it. What was also interesting to me was I had inside tire wear front and rear, even with -2 camber. That's not a lot. With these springs the Jetta had zero body roll, felt very controllable, and didn't lift a wheel. But at times it was a little bouncy, like it was over-sprung. I've been told by Koni that the coilovers can accommodate spring rates up to 700 lbs. I think the problem, however, was that the springs were just too stiff to allow any compliance given the weight of the car (2780 lbs. in race trim).
This year: I'm hoping the Golf will weigh in at about 2,500 lbs, (it was 2,635 last year) and most of the 135 lb. weight reduction will come off the nose of the car. That will make the nose about 1500 lbs. instead of 1635 or so as it was last year. It means the weight distribution will be 60/40 instead of 62/38. That's a good thing.
Originally my plan was to eliminate the rear bar and run 550F/400R with no bars at all. But my research has provided lots of conflicting data. Some people say run stiffer rear springs with no rear bar, others say run a front bar because if you get the front springs stiff enough to prevent body roll you'll have too much spring for track irregularaties. And I'm probably going to get the car a bit taller front and rear for best possible geometry. And this year I'll have a Quaife so the front bar/traction issue isn't relevant.
Here are my options:
1: 550F/400R, either with or without the rear bar
2: 400F/550R, no bars at all
3: 300F/300R, 26mm front bar, Shine rear bar
3: 350F/200R, 21mm front bar, Shine rear bar
The third option is closest to (as near as I can decipher from the spec sheets on VW Motorsport) the Golf 4 tarmac setup. They used a 30mm front bar which I don't think is available, and I'm not sure what they used in the rear. Also, I'm certain that their car was lighter than mine will be, which is why I'd go for 300 lb. springs instead of the 250 they used. The Shine VR6 Front springs are supposed to be about 250 lb., and they were way too soft for the track when running w/o a front bar.
The fourth option is running the springs that came with the Konis, putting the front bar back in the car, and leaving the Shine bar in place. Aside from cost (zero), the benefit of this setup would be much better compliance for bumpy tracks, and the fact that I know the dampers are valved well to work with the springs. Ride quality would be better going to and from, but I never really minded the 700F/550R setup in the wagon, remarkably.
I want to limit body roll and lifting the rear wheel, because both result in less grip. I'm hoping the weight reductions I'm doing will improve front/rear balance. And since this year's events with my club are mainly on rougher tracks (NHMS, Tremblant, Watkins Glen) I want to be sure I'm not over-sprung. The Golf will be a good 200 lbs. lighter in the nose than IBW.
I know TDIClub isn't exactly the center of the universe when it comes to racing, but I don't seem to be finding a lot of good data elsewhere. Most people make a few suggestions, then say it's better to simply buy a Honda, because it's lighter, has a better suspension, and makes the same power. That's not really helpful.
So let me know your thoughts, especially if you've tried setups on the track that you think have worked well for you.
Thanks!
Thanks!
