Old April 3rd, 2020, 09:15   #1
rhinorear
TDI(s): 2014 JSW
Default OBDeleven & Recirculating Air Control
Right now my control defaults to allowing outside air in after start up. Can I use OBDeleven to switch the default setting where it is recirculating inside air after start up? 2014 JSW
If so, how?
Thanks & hope you're healthy
rhinorear is offline   Reply With Quote
Old April 3rd, 2020, 10:03   #2
Lightflyer1
Lightflyer1's Avatar
Just turn the temp to max cold. That usually does it automatically on mine.
Old April 8th, 2020, 08:53   #3
rhinorear
TDI(s): 2014 JSW
Thanks for the suggestion but I'm trying to get away from excessive driver input to get the cabin the way I want. If the beast would just remember how it was when I shut if off we would be golden
Old April 11th, 2020, 14:13   #4
Martin Winterkorn
If so, how?
OBDeleven does let you set recirculation memory, it is listed as "Air recirculation memory' in the apps. If recirc was on when you turned off the car it will turn on automatically when you start the car. I just did this to mine a few weeks ago.
2015 Golf SE DSG w/ VW Fix
Martin Winterkorn is offline   Reply With Quote
Old April 20th, 2020, 08:42   #5
rhinorear
TDI(s): 2014 JSW
I want to thank you MW for the tip. I ended up finding it under Control Units / Air Conditioning / Long Coding. But was successful. Don't know if we have different versions of OBDeleven or not.
OBDeleven & Fuel Filter Change rhinorear OBD Scanners 8 August 18th, 2019 16:26
recirculating/fresh air button doesn't work!! vwfan7019 TDI 101 9 April 22nd, 2014 13:23
recirculating air/ fresh air is constant TDI-AHOLIC VW MKV-A5 Golf/Jettas 11 June 16th, 2010 19:31
No heat when recirculating the air freebsd VW MKIV-A4 TDIs (VE and PD) 0 January 4th, 2007 09:21
recirculating air and defrost boyelectric VW MKIV-A4 TDIs (VE and PD) 11 February 23rd, 2001 04:21
Page generated in 0.16395 seconds with 11 queries
[Output: 67.96 Kb. compressed to 60.14 Kb. by saving 7.82 Kb. (11.51%)]
