Go Back   TDIClub Forums > Picture Gallery/Specs of Members' TDIs > Other TDI/Diesel Picture Gallery
Other TDI/Diesel Picture Gallery Do you have a TDI or Diesel not listed above? If so write a message here describing it and insert a picture if you have one. If you don't have one on the computer, email me and I'll give you my address and I'll scan it for you. If you need web space for it, email me as well. Please make a short yet descriptive title for your vehicle.
Old November 5th, 2016, 13:06   #16
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
Originally Posted by nokivasara View Post
Yeah, I have a low-stress environment to work in! Unless you get wound up by having wolves and bear around you
I'm a forester, this was the scenery I got to spend my day in yesterday.
Nice...a little jealous of the scenery, but I don't envy the cold. I was sniveling this morning and it was only 2 centigrade.
2010 4D CWhite Golf TDI, 6 sp manual, Fluidampr, Bixenons, Rear Airbags, RNS-510, Dynaudio, DieselGeek SS & P2015 bracket, Force Fed Eng. Shifter Bushings. XB,UB, & RB UNIbraces; TyrolSport Brake Caliper Bushing, 2Micron Contain/PureFlow kits & timing belt cover, PolarFis MFD module, Euro light switch, R Red LED Tail Lights,Under Seat Drawers, Full color MFD cluster.
bobt2382 is offline   Reply With Quote
Old November 6th, 2016, 05:08   #17
nokivasara
nokivasara's Avatar
Fuel Economy: 44-49 mpg
It's not that cold around here, maybe about -20C during the coldest period. Now it's just a few degrees below freezing, that's better than a few degrees above freezing because the air is drier. Good clothing is all it takes
2008 Skoda Octavia 4x4 TDI PD/105 BLS
2014 mk7 VW Golf 1.6TDI (hers)
nokivasara is offline   Reply With Quote
Old November 6th, 2016, 18:33   #18
da.hs
Mild.. -20C is our "normal" temperature December through mid March. -35C from time to time. Haven't seen -40C for a few years. January 2004 had four continuous days at -52C - no diesels running in that week. My dentist moved here from northern Sweden - said he was tired of the long nights in Winter back home (we're only 53N).
da.hs is offline   Reply With Quote
Old November 6th, 2016, 22:55   #19
nokivasara
nokivasara's Avatar
I agree, it is pretty mild which is nice, less work with heating and basically no risk of frostbite.
I grew up in the north, almost by the arctic circle and the winters up there are cold and dark. You really don't want to shut your car off during the day when it's below - 40c if there aren't any outlets nearby
But I am thinking of moving up there again, we've had lousy winters around here the last 5 years and I can't stand it. When it's too warm for snow it only rains and it is dark and moody week in and week out.
This year is different, we probably have a foot of snow by now. Looks promising!
Old November 18th, 2016, 08:22   #20
nokivasara
nokivasara's Avatar
I wasn't happy with the mileage on this car it has the same engine as our Golf but obviously different drive train being a 4x4. It's also taller and it has rails on the roof so I knew it would use more fuel but lately I've been getting 6.7l/100km or about 36mpg when driving very carefully.
Today I checked the torsion value and it was -3.9 (or -3.7) so I adjusted it to 0.0, I hope that will increase the mileage. Haven't checked the torsion value on our Golf yet but it gets 46mpg without even trying so I hope to get at least over 40 with my Skoda now.
I also cleaned all the grounding points I could find, I have a 17911/P1503 fault code on it. It still charges the battery so I don't know what's wrong, I get over 14V over the battery with the engine running.
Old November 23rd, 2016, 11:32   #21
nokivasara
nokivasara's Avatar
I found a broken wire in the harness from the alternator, about half-way to the engine bay fuse box. That also fixed another fault code that I noticed it had stored, I think it was a 01314.
I was eager to see what the adjusted torsion value led to so I fuelled up when the tank was half empty. Old mileage 6.7/100km, new mileage 6.1l/100km (39mpg?)!
That was after a road trip to Stockholm so mostly highway driving but also some rush hour traffic in the city.
It'll be interesting to follow up that during the winter.
Old December 17th, 2016, 08:23   #22
nokivasara
nokivasara's Avatar
I need more ground clearance!
The 4x4 system is quite handy, I can feel how it shifts more power to the rear axle sometimes if I go around a turn fast enough for the front end to loose grip. This happens way before the traction control system cuts power and starts braking. I haven't gotten stuck yet so I don't know how good or bad the system is in those situations, the net is full of people complaining that it's not a real 4wd. I'm happy with it so far!
Old December 17th, 2016, 09:30   #23
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
Thanks again for sharing.
Old December 21st, 2016, 03:04   #24
German_1er_diesel
German_1er_diesel's Avatar
TDI(s): BMW 118d
Swapped the spotlights to a led light bar, it's a 75w cree bar. Not as bright but better than with just the stock lights, that's for sure.
Doesn't look Swedish enough without the spotlights though!
BMW 118d hatchback
German_1er_diesel is offline   Reply With Quote
Old December 23rd, 2016, 09:19   #25
nokivasara
nokivasara's Avatar
That's true!
We do like our aux lights here, in the land of eternal darkness (@winter)
Old January 1st, 2017, 18:52   #26
GetMore
Fuel Economy: 56.1/42.7/38.1
How does that car compare to the Golf in size? The nose looks kind of like a Passat, but I am not sure what the back looks like.
I am trying to figure out what the equivalent VW model is.
1997 Passat TDI, RC2, RR .216 injectors, needs a headgasket. For sale.
2010 Jetta Sportwagen, 9W7, Euroswitch, Ed's lights, fog lights, mud flaps, Malone Stage 2 and DSG tunes. Still has full emissions.
GetMore is offline   Reply With Quote
Old January 2nd, 2017, 09:59   #27
nokivasara
nokivasara's Avatar
It's about the same size as a Jetta/Golf wagon, the running gear is shared with mk5 Golf.
Old January 2nd, 2017, 10:23   #28
GetMore
Interesting. It looks (to me) like it shares a lot of the Passat's styling. I like it.
Old January 2nd, 2017, 22:56   #29
German_1er_diesel
TDI(s): BMW 118d
This generation of Octavia (MkII) is based on the MkV Golf wagon, same wheelbase and all. Cargo volume with the seats down is 1630L (1550L for the Golf). Škodas are always a bit roomier.
The current MkIII Octavia has a longer wheelbase than the Golf MkVII and therefore has more room in the back row and more cargo volume. (Golf wagon: 1620L, Octavia wagon: 1740L)
BMW 118d hatchback
Old January 4th, 2017, 11:21   #30
nokivasara
nokivasara's Avatar
We have a 1-car garage, was going to make it bigger last summer but didn't have the time. Maybe next year
octavia 1.6 tdi kylobeddo General Automotive 0 August 14th, 2014 06:50
2008 Jeep Laredo 4x4- trade for a TDI! TDI_01 TDI Cars for Sale/Wanted 7 October 27th, 2010 14:42
octavia tdi goes nuts far_cry TDI 101 4 December 30th, 2009 13:18
Car and Driver: 2008 TDI Jetta named one of 2008's most fuel efficient surprises Tahna Los TDI News/Tech 162 February 3rd, 2008 14:50
Skoda Octavia TDI's Stateside? Arcturus VW MKIV-A4 TDIs (VE and PD) 9 June 7th, 2000 02:02
© 1996 - 2020, All Rights Reserved
Page generated in 0.15990 seconds with 11 queries
[Output: 134.00 Kb. compressed to 112.00 Kb. by saving 22.00 Kb. (16.42%)]
