Old April 22nd, 2015, 15:27   #1
lawnarjax
lawnarjax's Avatar
Default Highway Miles vs. City Miles/EGR System Question
So I just purchased a 2010 JSW TDI with 105k on the OD, was able to speak to the previous owner and he states 85-90 percent of those miles were highway traveling from florida to vermont on a regular basis. Now aside from what we all know about the benefits of highway driving vs. start/stop driving on any car, and assuming what he told me is true, is there any benefit to the EGR system on this engine that these were highway miles? Has anyone been able to link any driving style or other variable to the EGR issues this engine seems to suffer from? I have a feeling there may not be any answer, and that it's luck of the draw when it comes to this very complicated EGR system.
Reason I ask:
This vehicle was purchased because I travel extensively for work, and regularly put 500-1000 miles on a rental each week. My company will also reimburse me @ 57.5 cents per mile, so I was leaving money on the table in my estimation. Even after fuel and a healthy maintenance allowance I will conservatively make 150-450 dollars a week. The car will pay for itself in less than a year. That's after setting aside 200-400 a month for maintenance. As long as the car remains relatively free of major issues, and I perform regular maintenance as prescribed in the manual/service guide I should come out ahead...Am I being too optimistic?
BTW I own another 2010 JSW TDI that just turned 85k miles and it is throwing an EGR code on and off, dealer wants $2200 to replace that whole system, but AFAIK it's not effecting mileage or performance yet, so I am not inclined to spend the money right now. If this new car generates the cash flow I predict I can recycle the money back into both cars over time.
lawnarjax is offline   Reply With Quote
Old April 22nd, 2015, 16:31   #2
frugality
frugality's Avatar
Fuel Economy: 33mpg
When you refer to the EGR system, are you only referring to the Exhaust Gas Recirculation system(s)?
The reason I ask is that there are other things to consider, like the DPF. I do a lot of highway, and based on the ash load number, expect to have to replace my DPF and some related parts at about the 200k-mile point, at a cost of ~$2400. That negates a lot of fuel savings, and is giving me cause to rethink diesels for my next car purchase.
I just ask because in my mind, the DPF is a bigger issue than the EGR system. And I'm guessing the $2200 for EGR work is high and you can get it done for less elsewhere. Sounds like the dealer doesn't know what's wrong and is doing the typical "throw a whole bunch of new parts at it and hope it works" thing.
2016 GTI SE 6M with lighting package, runs on RUG, has spark plugs? AVERAGING 33mpg!
2010 Jetta Sportwagen TDI, 197,089 miles, Silver, manual, 17" Goals, original brakes -- GONE; REPURCHASED BY THE MANUFACTURER.
frugality is offline   Reply With Quote
Old April 22nd, 2015, 16:36   #3
autoxerwgn
I thought that the majority of EGR flow code problems are due to a clogged EGR filter. A clogged EGR filter, is generally caused by a cracked/broken DPF which allows the soot to get into the filter. I would think you should be questioning the longevity of the DPF and it's chances of cracking/breaking if you are worried about the EGR system. Most people seem to believe that interrupting regens can lead to premature DPF failure, but not sure if anyone actually has data to support this. One would also think that it would be much more likely to interrupt a regen if a car is used mostly in city driving and especially if used for shorter trips too.
2011 Jetta Sportwagen TDI DSG
Eibach Pro Kit Springs, Malone Stage 2 and DSG Tune
autoxerwgn is offline   Reply With Quote
Old April 22nd, 2015, 21:34   #4
lawnarjax
lawnarjax's Avatar
Thanks for the input, I really had not considered the DPF as the culprit, and I guess that is because I have not been reading enough. I need to read up on the DPF it sounds like. Even if I had to replace the DPF at $2400 I would make that back in 12 weeks max, but you are right, the margins get real thin with it's not a sure thing. The one thing I have going for me is that the reimbursement rate increased to $0.575 a mile.
Well I am in it for the long haul, perhaps I will chronicle my experience here for the sake of others.
Old April 23rd, 2015, 17:59   #5
Corsair
Corsair's Avatar
Fuel Economy: 52/48/??
Admittedly, not exactly answering OP's core question, but... re last part of OP... the car with 85K throwing EGR code... Aren't the emissions components warrantied for 100K miles ? Why is dealer thinking they're going to charge money ?
Separately, I don't know this first-hand, but I've read on here that a look into the exhaust tips (where they exit at rear of car) can give a quick indication of DPF health; any soot seen in the exhaust tips means the DPF is cracked. At least, that's what I read....
Best Regards.... Corsair....
2002 Jetta GLS TDI 5-spd 325Kmi, 2014 JSW TDI 6M
2006 Audi A4 Quattro Avant 2.0T 6M
2004 Jetta GL wagon 2.0L (gas) 5-spd (sold)
[also had 03 TDI GLS 5spd wagon bought new, sorely missed]
Corsair is offline   Reply With Quote
Old April 23rd, 2015, 19:43   #6
Kevinski4
Kevinski4's Avatar
OP, your DPF is cracked, there's nothing wrong with your EGR (other than a clogged EGR filter from a cracked DPF. And the warranty is 80k... But if you have record of taking the car in before the 80k mark with the P0401 code, I would fight like mad for a free DPF.
Kevinski4 is offline   Reply With Quote
Old April 23rd, 2015, 19:45   #7
lawnarjax
lawnarjax's Avatar
Yeah I'm going to check back with the dealer this week. Also I discovered something cool on the drive from Orlando To Jacksonville today. 2 things really. First the car gets better mileage at 80mph than 75mph...and most of the way back up I-4 and I-95.Is typical road surface. But once you hit the inside of the beltway in jax the road turns into a light concrete looking surface which appears to have been combed with a very fine toothed brush. The mpg jumped from high 30's to a steady 48-50 mpg. Any thoughts on this?
Old April 24th, 2015, 08:00   #8
iamatt
iamatt's Avatar
Fuel Economy: 45
Never noticed but less rubber on the road? WE have those here. Sounds like you tearing up the tires when you ride on combed highways.
2014 Jetta TDI sedan (new) ,2014 TDI Jetta Sport Wagon 6MT (Flooded) Amsoil HDD3000 20K OCI, GSP Mod (RIP Rosie 4/4/2015), 2011 Toyota 4 Runner SR5 (Flooded), 2007 Duramax (Flooded), slightly modded GSPv2 is here, Bellatrix "Bella" Hunting God's County, katygsp.com
Amsoil Dealer -
http://www.texas-synthetics.com
iamatt is online now   Reply With Quote
Old April 24th, 2015, 08:23   #9
Georgia_Boy
Georgia_Boy's Avatar
Fuel Economy: 48-52 mpg
Before removing my DPF, EGR, and installing the CR170 turbo my car would get into the mid 40's around 80mph but only high 30's round 75. I just figured it was related to the power curve. Since my mods I'm in mid 40's at 75 and 80. I have noticed a slight bump in MPG on concrete compared to asphalt but nowhere near that significant.
CR170 turbo, Buzzken exhaust (straight), Race Pipe, Neuspeed turbo discharge pipe, Malone Stage 3 Tune, Dieselgeek sigma short throw shifter, 5% tint.
Georgia_Boy is offline   Reply With Quote
Old April 24th, 2015, 08:28   #10
S2000_guy
Corsair, the emissions equipment warranty is 80k miles on certain items; nothing is covered longer, to my knowledge.
http://www.epa.gov/obd/pubs/420f09048.pdf
S2000_guy is offline   Reply With Quote
Old April 24th, 2015, 08:59   #11
lawnarjax
lawnarjax's Avatar
The JSW I bought was just stolen!!!
Kind of...
So when I picked this car up at the dealer on tuesday I immediately noticed the strong color resemblance to a ford mustang my wife owned when we were dating, she has always wanted another car that color. I made a joke to the car salesman that my wife would probably steal this one for herself and give me the Salsa Red one.
I did not tell my wife I got the car, I wanted to surprise her, so last night I pulled in the drive after coming home from my trip and her eyes lit up and I know it was all over.
She took it, but I am swapping the wheels out and keeping the 17's.
Happy Wife Happy Life
New Car Highway Miles windward01 TDI 101 11 October 21st, 2012 06:27
Why are highway miles "easier" than city miles? tlhfirelion TDI 101 31 January 27th, 2012 03:46
First miles all highway cookie48 TDI 101 5 June 10th, 2009 16:40
Tranny Problems only after 90 miles of highway driving farmdwg VW MKIV-A4 TDIs (VE and PD) 6 July 27th, 2007 04:06
shocks/struts toast at only 45K HIGHWAY miles? concours Upgrades (non TDI Engine related) 2 August 25th, 2002 17:32
Page generated in 0.17267 seconds with 11 queries
[Output: 106.79 Kb. compressed to 90.88 Kb. by saving 15.90 Kb. (14.89%)]
