Old May 14th, 2019, 14:44   #1
LG7N
Default New Spice Red 04 TDI Wagon
So....new to this particular forum but have been on Vortex for 10 years. Recently I talked my fiancť into her first VW. Iíve owned MK2,3,4 platforms and have owned many MK3s which I love. I built a Surf Green 95 Golf Sport with a VR6 swap a few years ago from a stripped shell. I love that car. However, I have to say that this wagon is ridiculously fun to drive.
Iíll post the entire story because itís ironic how we acquired it as it was not planned. Well cared for is an understatement and it has a good amount of upgrades Iím still learning about since I know jack about TDIs.
LG7N is offline   Reply With Quote
Old May 15th, 2019, 17:14   #2
LG7N
A few weeks ago I helped a friend of mine and found him a TDI wagon that was a second owner car in excellent shape. I had never driven a TDI wagon and loved it. Totally stock. Had he not bought it I would have in a heart beat.
About a week later I woke up and happened to look on CL and saw another one in spice red in MA. All maintenance records since new CA/CO car for much of its life. A huge stack of paperwork. Kerma 150 tune, S7 turbo, refurbished head, southbend stg2 clutch, and a bunch of other odds and ends. All the work was done within last 20k also. The guy who owned it was incredibly nice and pretty ocd.
Today I refreshed the whole front end. New FAG wheel bearings, ball joints, control arms, inner outer tie rod assemblies. Did fuel filter, oil filter oil change, oil cooler seals, new shift knob and boot, smoked turns, leather GTI steering wheel, and a few other small items I replaced.
Old May 17th, 2019, 10:07   #3
LG7N
Much better than the stock Jetta wheels.
Old May 18th, 2019, 08:45   #4
sriracha
Fuel Economy: 40mpg+/-
Nice looking wagon! These mk4 TDI’s are fun to drive. I kinda stumbled upon my wagon, too.
sriracha is offline   Reply With Quote
Old May 22nd, 2019, 17:54   #5
JDSwan87
Black Swamp Thing
JDSwan87's Avatar
You bought Guatav's wagon...
http://www.forums.tdiclub.com/showthread.php?t=498488
Stella (Mine now): 2005 Shadow Blue Jetta Wagon TDI 09A
Mods: RC1. VCDS HEX-CAN USB (near Toledo, OH)
JDSwan87 is offline   Reply With Quote
Old May 23rd, 2019, 05:55   #6
LG7N
Originally Posted by JDSwan87 View Post
Yep thatís the one
Old May 29th, 2019, 08:00   #7
LG7N
2004 Spice Red Volkswagen Jetta GL TDI 1.9L Turbo Diesel Wagon, BEW engine
SERVICE HISTORY:
*Purchased NEW at Gebhardt Automotive in Boulder, CO on 04/29/2004 with 312 miles
on the odometer.
*BG Recall was completed and Radio/CD player was replaced under warrantee at
10,417 miles on 09/30/2004 by McNevin VW Dealer in Berkeley, CA.
*EGR Cooler Valve recall (M6) was performed at 56,728 miles on 09/14/2006 by
Broadway Volkswagen in Oakland, CA
*Brake Light Switch Recall (N4) was performed at 63,107 miles on 05/02/2007 by
*Flushed Hydraulic System with Super Blue on 09/2007 Clutch, LF, RF, LR, RR
*Timing Belt water pump, timing belt tensioner, tensioner roller, and accessory belt was changed at 83,951 miles on 08/13/2008 in CA.
*Glow plug recall (R8) was done at Morong Falmouth VW Dealer in Falmouth ME on
08/06/2009. ECM software was updated per VW Guidelines.
*Oil Pan was replaced with steel insert at 92,376 miles on 12/03/2008
*Windshield replaced 11/10/2009 (several rock chips and a 4Ē crack from one hit the
lower edge of the windshield).
*110,944 EGR leaks confirmed. Diesel Geek EGR Delete kit installed at 111,012 miles on
01/20/2010.
*Parts replaced on 02/01/2010 @ 111,693: (1) Alternator, (2) Left front ABS and Brake
pad wear sensor wire harness, and (3) ABS Speed Sensor. Codes Cleared.
*RocketChip Stage I+ 2/12/2010 ECU w/ EGR Delete
*Replaced brake pads (front & rear) on xx/xx/2010 at XXX miles.
*Replaced LF wheel hub assembly, wheel bearing, and ball joint on 09/03/2010 at
120,704 miles.
*Bilstein struts and shocks installed with all new mounts and bushings (Replaced RF ball
joint) on 10.07.2010 at 122,387 miles
*Thrust alignment performed on 10/11/2010 at 122,434 miles
*Timing Belt Replaced on 2/4/2013 @ 156,221 miles; Frost Heater installed. Skid plate
installed. Walker VW, Barre, Valve
*Replaced brake pads and rotors (front & rear) on 03/13/2013 at 158,082 miles at The
Source Berlin VT
*NGK 7v Glow plugs installed @180,056
-- - - - - - - - - - - - - - - - - - - Car sold to AM
*New rear pads and rotors. ID parts. @182k 10/2015
*Brakes bled LF, RF, LR, RR with ATE fluid @ 182k
*New parking brake cables (heavy duty) @ 186k
*New signal stalk, front right ABS sensor, headlight bulbs, Dieselgeek short shift kit, first
gear getter and radio repairs @196k
*New rotors and pads, front and rear (weak pedal and very rusted old rotors). ECS
Geomet and Hawk pads, new rear slides, Tyrolsport brake stiffeners on front @201k
*New DMF Clutch kit, Rear Main Seal, Slave cylinder, Transmission oil, Coolant, L and R
CV joint/axles, L and R ball joints at Shaftsbury Auto @203k, 12/12/16
*Turbo replaced with Borg-Warner S7 v.2 from Kerma TDI, new braided steel flexible oil
supply line. Chris at Kerma TDI Ext. 117, labor at Eurozone Motors @ 206k, 2/2017
*Valve cover gasket replaced. New Viton seals on boost pipes in engine bay, boost collar
at intake manifold. EGR valve cleaned @207k miles, 3/2017
*New set of Continental PureContact 2 tires. @207,800, 3/2017. Road Hazard from Tire
Rack, Reference Number(s): 440013310601, 440013310602, 440013310603,
440013310604.
*New pierburg tandem pump, new oil dipstick tube, new turbo oil return line gasket
@215k 8/2017
*South Bend Stage 2 daily clutch, 22lb SMF, new rear crankshaft seal, bolts, etc. New
OEM cam with lifters, bearings, etc., new valve cover w/ gasket, replaced oil cooler
gasket, tandem pump gasket, 3 bar MAP sensor, Kerma TDI tune, new shocks+struts,
alignment, tires rotated. @216,500mi 9/2017 Left Lane Cars, NJ and Waltís, VT
*RCN-210 radio installed 5/2018
*Front left wheel bearing (whole spindle) replaced, radium catch can installed 6/2018
*Brakes bled 4/2019
235-238K timing belt due
OIL and FILTER CHANGES
All oil changes performed with oil that meets 505.01 specifications at 10,000mi service interval.
4,900 miles on 07/07/2004.
10,564 10/5/2004
20,080 + changed fuel filter, air filter, cabin filter 4/01/05
30,051
40,008 + Changed air filter, fuel filter
48,511 06/24/06
58,000 + Changed fuel filter 11/2006
65,000 + Changed fuel filter cleaned air filter 6/2007
74,400 + Changed fuel filter cabin filter 11/28/2007
82,630 08/02/08
84,100 Fuel filter only changed
92,370 + oil pan 12/3/2008
102,180 + fuel filter
110,944 changed fuel filter
111,400 + air filter and cabin filter (Air filter very dirty) 01/11/2010
122,434 mi
138,200 on 10/22/2011 Changed oil/oil filter/ fuel filter and bled brakes
149,518 on 8/20/12 + air filter/cabin filter and headlight lenses
159,219 on 04/19/13 changed oil/oil filter
168,129 mi
176,453 + fuel filter, air filter
185,200
194,500 + fuel filter
196,200 only air filter and cabin filter (both dirty) 8/2016
202,800 oil/filter, + fuel filter 12/2016
206,900 oil/filter + air filter 2/2017
215,500 oil/filter//fuel filter/air filter 8/2017
216,500 oil flushed twice for new cam 9/2017
221, 450 oil change w/ filter and air filter 11/2017
228,0000 air filter and cabin filter replaced 6/2018
230,500 oil and filter change 9/2018
Car sold to Eli*********
236,000 oil filter (Mann), oil change (Pentosin 5w40 Syn 505.1), fuel filter (Mann), new oil cooler seals top/bottom 5/2019
Fixed charge piping to intercooler that was not seated properly 5/2019
237,000 replaced both front headlight bulbs with correct 9007 basic bulbs, replaced fender turns with smoked lenses DEPO, replaced bumper cover turns with smoked lenses DEPO, replaced dimmer switch OEM VW, replaced entire headlight/wiper stalk assembly with OEM VW, replaced battery holder bracket with clean OEM VW replacement, replaced upper front strut cap covers OEM VW, replaced steering wheel/airbag with OEM VW leather MK4 GTI 3 spoke steering wheel, replaced shift knob and boot with new aftermarket, corrected backward installed license plate light assembly 5/2019
236,300 replaced LF/RF wheel bearings with FAG bearings (hubs were still practically new did not replace), all new control arms/bushings LF/RF, ball joints LF/RF, and complete tie rod assemblies inner/outer with new boots LF/RF with LEMF÷RDER parts from FCP Euro. All torqued to VW specs 5/2019
Fresh alignment 5/2019
Installed 04 Beetele convertible wheels with Goodyear tires 6/2019
Old June 4th, 2019, 17:21   #8
LG7N
Was reading about diesel additives. Is it wise to run one all the time or just in winter? I believe the previous owner was running it all the time.
Old June 29th, 2019, 07:11   #9
LG7N
Put some 16Ē Beetle convertible wheels on the wagon. Much better. Got three almost new tires then matched the third one I needed off eBay.
Old July 3rd, 2019, 10:39   #10
LG7N
Plum Island MA
Old July 3rd, 2019, 11:32   #11
Welcome to the Jetta Wagon world! I can say without reservation it's the best car I've ever owned, and I've had it longer than any other car. Bought new in '02, 389K miles now.
I have other cars, but this is the one I drive 80-90% of the time.
2002 Jetta wagon, 412K, RC3+; 1993 Mercedes-Benz 300D 2.5, 199K; 1997 Passat, 289K; '99.5 Golf, 262K; 2011 335d, 64K; 2015 Golf Sportwagen, 14K. Principal, http://www.idparts.com
Old July 3rd, 2019, 12:55   #12
LG7N
Thatís a nice looking wagon. Looks to be in fantastic shape. Iím leaning toward getting another one for myself in the near future. I have two other VWs but this thing is literally such a blast to drive. Iím starting to think itís more fun than my VR6 and FAR more practical.
Iíve been messing with VWs for a long time now and this TDI is just fantastic. Iíve always heard the stories about how awesome they are and now I see why.
Old November 17th, 2019, 09:00   #13
LG7N
Wagon has been great! Just put studded snows on, did timing, tensioner, hardware, water pump, cam crank seals, accessory belt, oil change and glow plugs. It got cold and been using the frost heater which is amazing.
Old March 31st, 2020, 15:57   #14
LG7N
Got an old school Yakima rack with bike attachments. Issue free through winter. Next Iím going to do a suspension overhaul and brakes.
Old April 28th, 2020, 04:54   #15
rocketeer928
rocketeer928's Avatar
Nice looking wagon, and your fiancť sure looks happy in that first picture. Enjoy!
2003 Jetta GLS TDI with RocketChip RC5-ASV-Euro tune specific to my performance modifications - Platinum Gray
yo
1970 VW Type 3 Squareback - Cobalt Blue (Birdie)
rocketeer928 is offline   Reply With Quote
2004 Jetta TDI Wagon Manual, spice red, Kerma TDI 150hp kit. New England Gustav TDI Cars for Sale/Wanted 3 May 12th, 2019 20:18
2004 Jetta Wagon TDI spice red spicy_red TDI Cars for Sale/Wanted 3 August 24th, 2007 09:48
Show me your Jetta TDI Spice Red guyfromtor VW MKV-A5 Golf/Jettas 22 February 18th, 2006 12:24
New 2004 Spice Red TDI Wagon spicy_red VW MKIV-A4 TDIs (VE and PD) 17 February 26th, 2003 20:56
Page generated in 0.16573 seconds with 13 queries
[Output: 129.40 Kb. compressed to 108.83 Kb. by saving 20.57 Kb. (15.89%)]
