ctnatureboy
I bought it brand new, have been the only driver of this vehicle, and it has never been crashed, flooded, or smoked-in. I'm getting out of VW, and diesel.
$13k
VIN# WVWSR61J45W042040
Clean/clear title in-hand
2004.5
Manufactured in Germany
Jetta wagon
BEW/PD
5 Spd
Sun roof
Factory 23mm sway bar
Cold weather package (heated mirrors and heated seats (yes they both still work))
Currently 162k miles but still drive it every day
OEM Black heated leather (was cloth)
Malone Tune
Dieselgeek bypas oil filter
Fumoto oil drain valve
Luk DMF/clutch (~30k mi ago)
Kerma TDI Doggie Collar
Cat fuel filter
New OE battery
Dieselgeek Panzer skidplate with FMJ
Evolution Imports 1" lift
Full front end refresh Audi TT LCA bushings
New Koni Yellows with new bumpstops, strut mounts, bearings, and hardware
Vented fender liner
Zimmerman rotors
TRW pads
AARodriguez lifetime armrest hinge and latch
OEM Monster Mats
Volxtuning glass headlamp covers
Defender-Tech lift pump motor (OE tan lift pump)
4 General Altimax Artic tires (on Monterey's now) and 4 Altimax Summers (on seelies now)
Fresh alignment
Trans oil just changed with VW oil
Brake lines flushed with ATE Super Blue
New coolant reservoir
New lift pump gasket
Dieselgeek short shifter
Deluxe Dieselgeek timing belt kit installed at 154k
Franko6 Stage 2 chrome plated cam, nitrided lifters, slotted bearings
Turbo: VNT-17 from IDParts with new supply and return lines
Fresh oil change with 5-40 Lubromoly Diesel Hi-Tech @ 161k
Just installed Bosal hitch. Towed once just to test it.
No rust or rot but there are two small stone chips. One on the edge of the hood and one at the trailing edge of the left/rear wheel well. There are also a couple small dents from a crazy ex-wife incident.
Everything works. No electrical nightmares. VW changed the transmission some time ago under warranty due to a reverse gear issue. The glow plug and sunroof drain recall have been done.
I will not part out, accept low-ball offers, or ship. Have receipts for all.
*Kayak, cargo box, and cross bars not included*
$13k
2004.5
Jetta wagon
BEW/PD
5 Spd
Sun roof
Malone Tune
Cat fuel filter
New OE battery
Vented fender liner
Zimmerman rotors
TRW pads
OEM Monster Mats
Fresh alignment
