cleaned up bay
tackled these while the drivetrain was out
found some previous damage to the gearbox, seemed to be holding up so i let it rock
ALH lump ready for prep
ALH and 02A, happily ever after ? ... customer got a free CR oil cooler upgrade due to the ALH cooler nipples interfering with the B4 front trans/engine mount bracket
backside showing the hybrid borg turbo on the stock B4 mani, clearance is super tight between the compressor housing and the ALH oil drainback channel, so close in fact that i had to flap wheel the block and use a thicker fiber/steel exhaust gasket to achieve clearance
perched in it's final resting place
had to clearance the front crossmember for the mk4 compressor... all new motor mounts BTW
some intercooler pipe mock up, stock turbo>IC pipe interfered with the ALH vacuum pump so had to be ditched for a custom piece
custom turbo>upper IC pipe elbow... the cone part came from my buddy's 3000gt vr4 intercooler kit that he modified and this was left over... my friend Geoff did the melt work to make one from two
