Stealth TDI
Pre-Forum Veteran Member
Hello,
I've been making slow progress to get my car rehabilitated and finally had the chance to start it after about six months of sitting with a dead battery and without a fuel tank. I added four gallons of fuel to the tank, used a vacuum tool to suck fuel up to and through the fuel filter, then connect the feed between the engine and the filter.
The car started right up, but idled a bit rough. I figured this was normal after a fuel filter change. It's been a while since I ran the car WITHOUT the lift pump. Now I have the standard fuel sender and no lift pump to prime fuel for me. Anyway, the car stalled after a minute or two, right as I was noticing a LOT of air in the fuel hose. I thought perhaps the fuel filter needed another prime. Nope, plenty of fuel at the filter outlet.
Each restart resulted in a shorter and shorter run. Now the car won't even start. Do I have an air leak? Or might the injection pump be bad? If a bad IP, would the clear fuel line be empty, with almost no fuel in it, suggesting the IP is not sucking fuel? Or would the fuel be in the hose and just not moving? Does the empty fuel line point more toward an air leak?
How do I rule out the IP or confirm it? Perhaps start and run the car from another fuel source that bypasses the entire fuel system before the IP? The car ran fine before I parked it in January.
Thanks!
Scott
Thanks!
Scott
