Old August 4th, 2013, 06:36   #1
V-Rod
Default Just passed 170K
I just turned over 170,000 miles on my Jetta TDI
So far I replaced the glow plugs twice, 1 set of rear brakes, and the DMF at 150K which could have easily gone longer Other then that just routine maintance. Even the factory battery tests good!
Everything on the car still works, and the car still runs and drives like new.
2014 Jetta TDI Premium with Nav, DSG
06 Jetta TDI DSG
V-Rod is offline   Reply With Quote
Old August 4th, 2013, 13:31   #2
Tarbe
Good for you!
Keep crappy drivers away from you, and you'll likely see many more miles.
My '09 had 171,600 miles on it yesterday, when a day-dreaming woman rear-ended me harder than Elton John! I was sitting at a red light!
It too was like a new car...the trip I was on was yielding 48 mpg. Car is now sitting in a wrecking yard in Conway, AR waiting to be called a total loss.
At least no one was hurt.
Be careful out there!
Tim
Two VWs sold back...see 'ya later. Maybe...
Tarbe is offline   Reply With Quote
Old August 4th, 2013, 14:05   #3
James & Son
TDI(s): 2006 Jetta
Thats a terrible think to have happen.
Anyways i can not post high miles out of a cam but I wouldn't mind Go Faster posting as he had over 400,000 kmeters last year. I know this may not be exceptional as other 300,000 mile cars do exist. But I would be interested as to how you decide what to do with a car with that many miles(kilometers). At the time of reaching the 400,000 mark he stated he needed a cam and EGR cooler and possibly other work.
170,000 miles at this stage is really not much. in 2010 that would have being something. Actually if you consider the bell curve of cam wear we are only now seeing the 200,000 plus come in. Where was the cam wear numbers peak for the BRM. Overall the BEW and the BRM should still generate a lot of cam sales in the next year.
James & Son is offline   Reply With Quote
Old August 4th, 2013, 15:00   #4
V-Rod
My car got a late start, I bought it new in Sept of 07. At the time it was a little tuff for me to past sticker for a 06 when the 08's were coming out. But I always planned to drive this car till it dies. As far as I am concerned the car could die today and I would have no complaints
06 Jetta TDI DSG
Old August 4th, 2013, 15:56   #5
Marinel
Marinel's Avatar
I'm right there with you on that one. Im confident that I could get my car to 300k miles. Its been one of the best care that I ever owned. Im currently at 182k miles.
06 Jetta TDI 5 speed. Full straight pipe, Malone stage 2, EGR Delete.
85 MB 300d 235k miles and still going strong.
Marinel is offline   Reply With Quote
Old August 5th, 2013, 10:04   #6
jjblbi
Fuel Economy: 41ish mpg post fix
I would highly recommend you inspect both your cam and more importantly your lifters. I had a lifter go at 184k miles, the top dished and it stuck partially open. All cam lobes looked fine and had the chamfer. Apparently you can't really check the lifters without pulling the cam. The car was running great, 44 mpg w/DSG; I bought and serviced (Mobil TDT) since new. My plan was to do the full inspection at 200k with the timing belt...never made it.
jjblbi is offline   Reply With Quote
Old August 5th, 2013, 10:41   #7
TDI smile
TDI smile's Avatar
I'm coming up to 300,000 km. Engine runs smooth and on the last trip to Edmonton, Camrose, AB I averaged 4.2/100 km (2 pax and a small Dog). I'll drive it until I'm gone or the car. Parts since new: Batterie, Brakes, 1 Cooling Fan, 3rd set of tires (Mich.), 2 Timg Belts. 3rd will come at 300,000 km
TDI smile is offline   Reply With Quote
Major engine failure at 170k Miles? dan30thz28 VW MKIV-A4 TDIs (VE and PD) 31 June 23rd, 2012 05:37
FS: 2004 Jetta 170K TallTim04 TDI Cars for Sale/Wanted 2 November 13th, 2011 04:23
B4V 96' 170K Feeler FS jasonTDI TDI Cars for Sale/Wanted 15 April 9th, 2008 22:10
170K on original brakes....Am i just lucky? SDMFer Ontario 15 March 9th, 2008 17:52
Woochow passed away. TDI_Don TDIClub and TDIClub Forum News, Issues, Problems and Suggestions 16 June 7th, 2007 12:06
Page generated in 0.13749 seconds with 11 queries
[Output: 81.20 Kb. compressed to 70.68 Kb. by saving 10.52 Kb. (12.96%)]
