I did get one installed last night. It runs quietly - as quiet as the original.
I did not get a chance to run flow and pressure data, but I suspect it is fine.
The replacement pump units are a tiny bit different from the originals. There are holes in the top of the pump unit, apparently to ensure coolant flow past the internals. So fuel comes shooting out of small holes in the top of the pump enclosure when you test it.
So you may want it down in a deep bucket to test it, not in a one gallon Bush's bean can. Just sayin'.
I found that I had to heat up the supplied hose in order to go over the fittings (and yes it is too short, just testing).
A good replacement hose seems to be the "dudadiesel hose"
http://www.dudadiesel.com/viton.php?...ng_id=17:18:US. You want the 5/16" ID hose.
It worked well, without kinking. The corrugated hose would be much better, but this does work.
Using a heat gun or hair dryer to heat up plastic when it is below even 60 degrees is a good practice. This plastic has been subjected to 160 fuel for 6 years or so. It is not as elastic as when it was new. A few minutes warming up can save a lot of time and energy.
If you end up needing any spare parts, let me know; I may have some laying around.
