GoneDiesel
- Joined
- Jun 2, 2000
- Location
- USA
For those with the '09 CBEA 2.0 Liter Common Rail TDI, Chapman VW in Tucson has been using non 507.00 VW Spec oil for oil services. Straight from the horses mouth they use Castrol TXT 505.01 for all TDIs. I stopped in to purchase a quart of the 507.00 to have on hand if needed. I gave the parts guy the part number (GVW052195M2) for the 507.00 spec oil and after a few minutes of looking around he asked what vehicle it was going in. I told him the 09 common rail diesel and that it should be 507 spec. He messed around with the computer and then came out with the wrong oil. I mentioned that was for the PD TDI engines and the new CR TDI required 507 spec. He said they have never had any of this 507 spec and that all TDIs no matter what year required the 505.01. I said the owners manual states only 507.00. He said they have changed many 09 TDIs and never used it. So my wife ran and got the owners manual while I walked over and spoke with the service manager. Same exact story from him. I showed him the manual. He left and returned with about 20 pages of oil charts supplied from VW. He had the page open to the Jetta GLI and pointed to the 502.00 or something. I said that was a gas engine and not the TDI. He said yep it is see 200hp and the 502.00 superceded 505.00. I grabbed the paper and flipped it to the Jetta Sportwagon and pointed out the CBEA engine (140hp) CR TDI and pointed to 507.00. He was silent for a while and then said this is pretty embarrasing. You know more about oils than we do. He also mentioned they have filled all TDIs with the 505.01. He said they would be getting the 507.00 in and have a meeting to get everyone on the right page. I will wait a few weeks and stop in again to see if they have any in stock. So if you have had any service done at Chapman VW in Tucson you may want to take a look at the oil they used and keep your service receipt handy. Please stop in and check up to see if they have the 507.00 spec in stock. Hopefully they will start stocking and using the correct oil if several people are in there requesting it. GD
