Old February 14th, 2020, 11:17   #1
Lavek6
Default Golf mk6 vibration
Golf mk6 2.0 tdi 103 kw
Few weaks ago i noticed some vibration sound when turning ( turning left is worse ) but only on low speed's 1,2 gear and only on accelerator with more than half turn, mechanic took a look since i noticed that just before i was doing my timing belt, and he could't find anything.
Now few days ago i noticed that when i let go of throttle beetwen 1500 and 1300 rpm diffrent kind od vibratio like something is loose and shaking (can't find anything) and it happen's in evry gear at same rpm, anybody have any idea what could i check?
Lavek6 is offline   Reply With Quote
Old February 15th, 2020, 03:22   #2
DivineChaos
flywheel, front dif, cv axles, wheel bearings, clutch. does it also do it in reverse?
DivineChaos is offline   Reply With Quote
Old February 18th, 2020, 13:04   #3
Lavek6
Flywheel and clutch are new 10000km changed in summer didn't try in revers but i can hear vibration if i push the clutch in and rev it up to 1500 rpm and let go.
As for the first vibration that started before when turning in reverse you can hear it same as 1,2 gear, it is diffrent sound but maybe could be connected.
Old February 18th, 2020, 13:40   #4
Pharcyde145
TDI(s): 2011 JSW 6MT
the constant vibration in different gears at a similar low rpm make me think tie-rod ends. if it's groaning while turning in reverse, I'd assume it is CV's. What kind of mileage (km's) do you have on the suspension and running gear?
Pharcyde145 is offline   Reply With Quote
Old February 19th, 2020, 10:52   #5
Lavek6
QUOTE=Pharcyde145;5572989]the constant vibration in different gears at a similar low rpm make me think tie-rod ends. if it's groaning while turning in reverse, I'd assume it is CV's. What kind of mileage (km's) do you have on the suspension and running gear?[/QUOTE]
Car is 190k km i bought it with 170k km so i dont know howold is suspension. Today a friend reved engine for me and i noticed that airbox is vibrating a lot and when i hold it sound is quieter because plastic isnt shaking but i can feel it like there is turbulence in air and is shaking the airbox and you can steel hear that sound just not plastic rateling, also sound does not apear until car is at 90C kinda like somenting changes andthen it starts, could it be something with turbo, i will remove airbox and make sure it is not doing anything underneath.
Mk6 Golf Monster Mats--$30 / 2012 OEM Springs-- $50 / Mk6 Cargo Mat--$20 durtydub Private TDI Items for Sale/Wanted 1 February 17th, 2017 23:27
Strange Vibration on MK6 Jetta PoochiePD TDI 101 4 November 8th, 2015 17:22
Transitioning to MK6 Golf TDI from MK6 GTI Anonymous911 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 10 May 16th, 2013 06:57
WTT: Portos (MK6 Golf) for Mambos (MK6 Jetta) dean_park Private TDI Items for Sale/Wanted 7 July 29th, 2012 19:59
MK6 Golfball Shiftknob, MK6 Stock Golf TDI Shiftknob RPS99SHO Private TDI Items for Sale/Wanted 0 August 9th, 2011 14:10
Page generated in 0.12723 seconds with 12 queries
[Output: 68.10 Kb. compressed to 60.33 Kb. by saving 7.77 Kb. (11.41%)]
