milleraw
- Joined
- Nov 17, 2003
- Location
- New London, PA
- TDI
- 2010 JSW Silver, Portos, Roof / 2010 JSW Candy White
\'96 Passat \"Turbo goes boom\"
OK guys...I really need your help now!!!
On my way to work this morning I got stuck behind a school bus. When the bus pulled off I put the pedal to the floor and the engine felt like it went to running on 2 cyls and then died completely. I assumed it was air in the fuel lines or whatever. After pulling over i attempted to start. 1st try was no go. 2nd try it came back.....However, this time I hear a loud turbo noise. Sounded like the blades of the turbo were touching the sides of the housing. continuing down the road a bit the noise was not getting better. I am beginning to think about turning around to go home... Then the noise stopped and the white cloud arrived. At this point I am sure it is the turbo and just need to get 2 miles home before the crank case is empty.
SO....What are my options? This turbo is most likely toast. I might be able to get a used one from the salvage yard.
Who does rebuilding? Can they replace impellers? Any help is greatly appreciated.
