Trunk will not open
y22man
SLC, UT
Hello All,
Over thanksgiving my trunk decided to stay shut. I must of made it mad.
When I try with the fob, lever on the door, or Key I hear the motor work but it still stays locked shut. I am about to crawl in to the trunk from the back seats to take a look and see if I can get it open with that lever.
I have had the trunk latch replaced by the dealer under warranty due to not latching shut when closed. But I am far from that now. Car is in sig. Any ideas?
cd2573
dutchess county N.Y
2014 bmw 328D
its problably the plastic piece that pushes the trunk open that broke also happened to mine they sell it all the dealer with the motor
Concat
Edmonton, AB
2005 Jetta GLS TDi
I'm don't suppose it's cold enough to have any compnonents freeze is it?
If so, try a hairdryer :)
y22man
SLC, UT
It was thanksgiving night when it was outside at the inlaws. But not since. Garage has had a median temp of about 43 at my house. Don't ask why I have this..... Sore topic with the wife.
LNXGUY
Barrie, Ont, Canada
'05 Jetta TDI Wagon
You can still open the trunk with the key, you just need to force it a bit.
Mine did the same thing, plastic actuator in the trunk snapped. Motor still makes noise, but it won't open :)
