Transmission - All Gear Lights On
gtrinker
New Jersey
2005 Passat Wagon
About a month ago I noticed occasional rough shifting into low gears... very intermittent. Then came the slight lurch after stopping quickly. Today I hit the brakes on the highway as the bonehead on front of me stopped to cut across the median. When I accelerated, there was what felt like slipping. Then I noticed all the gears were illuminated on the dashboard (photo attached in case that seems confusing) . The car was revving high and not shifting to a higher gear. I exited, tuned off the car and back on and all was normal.
I was suspecting low fluid and needed to get to the shop to see if there is a leak and to check the level. Now I am thinking electrical issue. It is a 2005 TDI Wagon. I had a rebuilt transmission installed about 80K miles ago.
Anyone experience this?
JonnyObnoxious
Newport, Oregon
05 VW Passat, 12 VW Touareg TDI
Your transmission dropped into limp mode. Check your transmission control module for moisture. It's under the carpet on the RH side. Pull the fault codes and start diagnosing!
If it makes you feel better, mine is stuck in limp.
Sent from my SM-G930P using Tapatalk
