RedTDIowner
Anyone know what type of bit I need to remove it? My torx set does not have the right one. Here is a pic of the screws I need to remove. My T25 is the closest fit but still won't work.
My daughters Lexus is throwing a code and so I bought a can of mass air flow sensor cleaner to hopefully eliminate the code on her car and then I got to thinking that maybe I should also clean mine since I bought it several years ago and the can says to clean the MAF sensor every time you change the air filter.Why do you want to remove it? When you buy a replace it comes as an assembly.
I only repeating what I have seen and heard on U tube , there is several and the one I watched lately I Scanner Danner, a smart guy to say the least , he teaches at a collage and also does trouble shooting for shop including dealers on electrical systems. Pretty interesting and very helpful . He uses scopes , meters , test lights ect to see what the problem is not a parts changer . From what I seen the air mass can get dirty and not meter the air proper and I seen the air mass cleaned and it worked . I want to see if the ground and ref voltage is proper. I not sure how the system works on your application , a wiring diagram might help . I watched Paul and one of his ex students , a master vw tech trouble shoot a TMC module and it was very helpful . It cost nothing for me or very little to watch these guysMy daughters Lexus is throwing a code and so I bought a can of mass air flow sensor cleaner to hopefully eliminate the code on her car and then I got to thinking that maybe I should also clean mine since I bought it several years ago and the can says to clean the MAF sensor every time you change the air filter.
