Rowingfish87
Having a stumble while the engine is cold and a miss every now and again at idle. No active or logged codes.
Checked injector balance with vcds, #1 is around +2 where #2 3 4 are between -0.80 and -1.05. Injector solenoid value is way off on #1 as well -43 vs - 10 avg on cylinders 2-4. Pulled the valve cover and cam lobes are still in great shape.
Seems like I'll need a new injector for cyl #1 at around $450.
Is there any reputable company who can rebuild this injector? I've seen where karma tdi will "balance" the injectors but was wondering if this one is too far gone to be balanced.
Any other ideas?
Any other ideas?
