migbro
Alternator pulley cotton ball trick
I took a cotton ball and soaked it in Kroil (you could use any penetrating fluid) and stuffed it in the recess in the alternator pulley hub. The cotton ball is just the right size for this and acts as a dam so a small pool of Kroil sits against the hub threads.
I let it sit for about an hour and the hub popped right off as soon as I torqued it.
I did mine not too long ago. At first my pulley wouldn't budge and I didn't want to overtorque it and break something.Ok - finally got all the parts (and the tool) and I can't get the remnants of the pulley to budge.
I have an extension on my 17mm wrench and have the 14mm wrench stuck against the frame. So far - the wrenches (one or the other) keep slipping off. I haven't damaged the tool yet - but I am afraid that I will. I sprayed a ton of WD40 in there and am letting it sit over night.
If that doesn't help, anyone have any other ideas?
