Hasenwerk
Vendor , w/Business number
- Joined
- Nov 28, 2003
- Location
- Quesnel, BC
- TDI
- 1982 Cabriolet (BEW|VNT17|Stage4), 1989 VW TriStar Syncro soon-to-be CR TDI (CBEA), 2001 Ford Ranger Edge 4x4 (ALH|VNT17|R520|Stage4)
My poor Ranger (ALH | 1749VB | Race520 | Stage 4) was still over heating during heavy shenanigans. Everything in the cooling system is new - VW MK3 radiator, new water pump, t-stat, temperature sender and even an external oil cooler and the overheating was getting worse over time and I was starting to notice some coolant loss - so off with it's head as this really sounds like a head gasket issue . . . The valves all look good, as do the pistons so off to the rebuilders to see if there are any issues with warping and get them to clean it up and do a re-install this weekend.
I was noticing with the head off that the pulley side of the engine is up 5 or so cm higher compared to the flywheel side of the engine. So is this something I need to worry about when adding coolant? I really want to solve this over heating issue once and for all. Is it going to self bleed or do I have to bleed the system with the engine higher on the flywheel side than the pulley side as there is no coolant output on the pulley side to purge air as there is on the flywheel side? Is there a "simple" way to add a bleeder screw to the belt side of the head?
